New finish mower needed
/ New finish mower needed
Have you looked at everything attachments.
yes. Some interesting alternatives there. I am new to the area and want to buy locally to develop a relationship with the dealer. They just helped me out by changing the points in my ancient Gravely that another dealer and repair shops, including the huge JD dealer, said they no longer know how to do points (amazing, huh?). But if their smaller Land Pride is too expensive, I'll go to TSC.
There is a New Holland dealer locally too;ought to walk in there just to look around. I'm sure they sell implements that aren't blue. JD's frontier line would do also.
So if a six foot finish mower costs in the 1200-1400 range, it will be interesting to see how much more the LP is. Or I'm sure a comparable Bush Hog, etc. King Cutter makes a nice unit too. I'm guessing LP's smaller mower will come in around 2 grand and the larger unit in the mid to high 2's. Will see and report back.
/ New finish mower needed #22
You have mentioned twice your desire to mow to a height of 7". I'm not aware of any finish mower capable of raising the deck to that height. Most max out at 4 to 5.25 " and to mow higher would require supporting it with the 3 pt hitch. A quick check of the specs shows the Woods 990 having a 7" mowing height and that is a monster of a mower. Your choices reqarding a 5' or 6' finish mower and that 7" setting are extremely limited, I,m afraid. Good luck.
I totally agree; everything I am finding maxes out at 5.25 inches. This is why I bought a swinging blade mower in the first place, to get more height. I guess I'm going to be mowing at 5.25 in the future; no sense reinventing the wheel.
/ New finish mower needed #24
Could the wheels be replace with larger wheels to get you up to 7 inches?
/ New finish mower needed #25
I would buy a rear discharge mower.I have owned woods and landpride model finish mowers and both were very good mowers.
/ New finish mower needed #26
I picked up a new Kioti RFM 72 and it has been an awesome machine, rear discharge, cuper clean cut, a few rocks and trees to go around, but for the 5 acre field, it makes it look like a real pretty semi manicured pasture
/ New finish mower needed #27
I tried a 6' Italian mower once. Stamped deck and stamped pivot wheel arms. It started stress cracking in the deck and pivot arms in one season. The Italian mowers may be better now but I'm against stamped anything now. A fabricated deck for me. I've owned two 6' Woods RFM mowers. A RM660 and presently a PRD7200. A Woods works best for me.
Whistlepig, was that a Caroni? My understanding is that some of the Italian models are higher end, but who
knows, it could be just marketing jive.
Likely there are half a dozen alternative models in the low two thousand dollar range. Mowing this field only takes me two hours to do now, though it's with a 7 foot mower, not a 6.
I like the idea about putting bigger wheels on the mower. Isn't likely to be a problem with the pto adjusting upwards a couple of inches and certainly the three point hitch will adjust plenty high. Alternatively I always wondered if one could extend the mount downwards, like punching another hole in your belt...but tires just seem like such a simple solution, as long as there is clearance left between the tire and the mower deck. That might be a gamestopper pretty quickly if there's only an inch there to start with. Now if the wheels are set out a ways, then why not?
reminds me of the old days when 31x10.50's were the cat's meow on a truck, if you could get the clearance without jacking it up.
I actually got them on a suburban way back when and they fit fine. Man what a terrible ride though; the new suburbans are mercedes compared to those old bouncy darty trucks.
so of course I'd like my new mower to handle the curves, and bumps, not mind an occasional fire ant hill to blend up, and leave the clippings in a way they are not noticeable, assuming I don't try to cut too much off at one time.
Kubota dealer with the Land pride mowers never returned my email. Guess I'll stop in there tomorrow.
/ New finish mower needed #29
Maybe could use same wheels and just add spacers to pivot on wheels sort of the way they do it on bush hog mowers
/ New finish mower needed #30
I won't say the brand. I will get flamed here. There are a few things that go on with finish mowers that I have learned. It has to be heavy or it will bounce on hard dry ground and beat itself to death. Tapered roller bearings in cast iron blade spindles. Not fabricated blade spindles. Anti-shimmy caster wheel springs or the caster wheels will beat themselves to death. Kevlar belt. And a fabricated deck.
If you are mowing with a RFM mower an hour or so a week most anything will do. Mowing 5 hours a week for the past 7 1/2 years like I have takes a mower that will last.
No stamped decks or stamped spindle arms for me ever again.
/ New finish mower needed #31
The supports for the pivot wheel arms began to crack and bend on my 84" First Choice (Sicma) finish mower within the first couple years.
I welded 1/2" plating all along the arm supports.
I've used it for years and hundreds of hours since with no problems.
I really like my First Choice mower since its been plated, but the stock arm supports are weak.
I also have a 72" side discharge Landpride.
I seldom use it. I prefer my First Choice mower.
one of the nice things about an 84 is that it clears the rear tires on my Kubota nicely; seemed I was getting less tire tracking/grass that popped back up a half hour later. I usually have to experiment a bit with a new mower but I guess this all gets down to how badly I want that extra foot of mower. And whether the manufacturer makes a seven foot mower in their lowest duty line. So far I'm seeing that entry level max out at six feet. The seven foot model is available in a heavier duty mower with a significantly higher price I believe. And I don't think the local dealers even stock one of these. Might get lucky who knows. But I sure want to put my hands on it before I buy it.
ultimately I would love to mount the mower up front. I think I can do it, but likely a stupidly high price to buy all the parts, though I do have full hydraulics up front. The Europeans seem to use a lot of front mowers. Wonder how they turn...boy that would take a little practice for sure. But at least you could see everything out front, and of course the mower is getting the grass before the tractor tires mat
it down.
The Land Pride mowers I own/have owned are both swinging blade types or what we all call bush hogs.
So I really know very little about tractor mounted finishing mowers. Never had one actually.
So I appreciate all the advice given. I have a tendency to overbuy and I'm trying not to this time.
I'm not a betting person but I can guestimate the six foot Land Pride will come in around 2200 and the seven footer in the next series up will come in around 3400. I hope I am pleasantly surprised if they come in less. Will let you know how good my guessing is.
/ New finish mower needed #34
Drew,
You just need to pull the trigger on an F series:
Just In: Kubota's F3680 Front-Mount Mower with 100 inch Mower Deck! | Fully Equipped
I looked hard at an F series Kubota but just could not justify the cost; I'm not a commercial user. And that mower deck is something like ten grand all by itself. But oh my what a rig. Though I bet it won't mow at seven inches.
Now my Gravely has a 50 inch mower and it mows nicely with its 40 inch wing mower, for 90 inches overall.
However, I found a second wing mower and want to make a trailing rig with 130 inches total. Will take a lot of welding.
It's a lawn only setup.
When I have time I will post pics; maybe some of you can help me design the trailing arms. The wing mowers do not trail directly behind but on an angle with very odd wheel setups so I have to recreate the Gravely trailing design for the opposite side, which it was never designed for. The Gravely is so high effort I can't drive it for long with my arthritis but it for sure is one of my favorite pieces of machinery. Maybe some day I'll figure out how to add a hydraulic steering cylinder for it, but for now, the JD X750 I bought for mowing has one finger super light steering, so I can steer with one hand and let the other one rest.
And the Kubota is certainly easy to drive; just need the right mower on back. What I have works adequately so not in a rush here. Maybe I'll buy the mower in January...
interesting that about every three years a new thread starts asking about finishing mowers. Guess we all want to know what is new and good out there.
/ New finish mower needed #36
I have been mowing the four acres or so of fields around my lawn at the new home with my existing 7 foot super heavy duty Land Pride bush hog mower. With the blades sharpened on it, it does an amazingly good job mowing the field nicely. But it does not, for sure, lay the clippings down nicely, nor was it ever intended to.
So I need a finish mower for my 50hp pto Kubota. Would like a seven foot mower but will stick with a six foot because I think that price point is more competitive and it really doesn't take that long to mow. And I'm in a/c anyway...
Tractor Supply is very close to my home. So is the Kubota dealer with Land Pride.
The challenge is that the Land Pride stuff is usually almost double what TSC or AgSupply or similar have in their own brands.
I own both TSC equipment and Land Pride, and it all works well.
No rocks, flat ground, want a better appearance. This area will be converted to a fruit orchard next year and I want to be able to mow around the trees with this mower also. I have a JD X750 with a 60 deck for the five acres of lawn, but want the field to look like a field, not a lawn.
Does paying twice as much for a finish mower represent any type of value? I see the Italians make a lot of these mowers, Caroni and others.
Would greatly appreciate feedback from finish mower owners as to their experience with quality of cut, reliability of mowers, etc.
I have trees on one side and white plastic horse fencing on the other. Usually mow at about 7 inches height.
thank you. Drew
I have the 6 foot Tractor Supply Company rear finish mower that I use to mow my yard, ditches, and an orchard area. The mower is made by Tarter Industries and virtually identical to any other rear fniish mower I have seen. The only difference between it and say the Frontier, John Deere, Kubota, BEFCO, Bush Hog, etc. 6 foot rear mowers is that it's about 50-100 pounds heavier than most of the others as it weighs just shy of 700 pounds. My yard is about half an acre of grassy weeds and relatively level although sloping as my house has a walk-out basement. I have about a quarter mile ditch along the road frontage and it's pretty level too. The PO mowed the yard and ditch with a Sears riding lawnmower. Now the orchard area was about an acre of former donkey paddock and is covered in stumps, rocky knolls, and has holes and bumps all over it. It also had 5 foot tall ragweed until I cut it down with my Dad's 5 foot Bush Hog. I use the finish mower to cut it all. I pull it with a Massey-Ferguson 1030L, which is about the physical size and weight of a smaller Kubota L (L3301/L3801) and has 23 PTO HP which is a bit smaller than your M-series Kubota.
The quality of the cut of the mower is equal to that of a riding lawnmower, ZTR, or pushmower and it handles tall grass much better than any side-discharge unit I've ever used. The grass simply falls out of the back of the mower in a fine, disperse covering when the grass is tall and it doesn't windrow or bog down like a side-discharge unit. I mow going about 2.5 mph with the grass length set to a "normal lawn" setting of about 2 1/2". That speed is mostly due to terrain and the need to maneuver around some obstacles like fences, stumps, and the house. I can keep up that speed without bogging the engine at all until the grass gets to be about a foot or so tall, in which case I drop down a gear and it continues as usual. The two issues I do have with the mower- and this will apply to all rear finish mowers- are that it's not particularly maneuverable especially with a loader-equipped tractor and that the wide deck can scalp if you hit a high spot wrong. The mower does have an anti-scalp roller but if the ground is soft, the mower is heavy enough the leading edge of the mower will simply act as a blade and scalp the ground.
As far as reliability is concerned, I've only used the mower for about 30 hours or so. I've had zero problems. The only issue I could foresee with you is that your tractor is more than twice as powerful as mine and has enough PTO horsepower to potentially wreck the gearbox in the mower, which is only rated to 40 hp. My tractor isn't strong enough to shear the typical 1/2" shear bolt used in this finish mower or in most light and medium-duty rough-cut mowers, let alone wreck a gearbox. It bogs and kills the engine if I rough cut something too big.
The Tractor Supply mower I have adjusts to a 5 1/2" cutting height like virtually every other mower out there. Larger guide wheels would not work as the wheels would rub against the U-shaped flange that connects the wheel axle to the guide wheel attachment bracket.
That's exactly what would happen. You'd need to replace the wheel flange with something with a greater flange top to axle centerline distance (e.g. the "legs of the U" need to be longer.) Either that or you need to change the pin at the top of the flange with something longer so you can add more spacers to increase the cutting height. However I'd think 5 1/2" is plenty tall for orchard grass. I mow mine at half of that. You can also always use the mower in "normal 3-point mode" where you don't set it all of the way down on the gauge wheels. You'd adjust the height with the 3-point like you would a rough-cut mower.
31s were "little" tires in my old days. The tires to have were 35" Super Swampers (35x12.50-15) and you had to put at least a 4" body lift to clear them on the half-ton 1973-87 Chevys and 1973-79/80-86 Fords people drove back in those days. You could usually stuff 33x12.50s with only one hockey puck worth of body lift. Yes, people used hockey pucks for body lifts as we were poor rednecks and didn't have a lot of money. Today the kids would have their parents go buy a proper Skyjacker suspension lift and put 37" diameter Nittos on 20" aluminum rims on their 2000s era 3/4 ton diesel pickups.
A rear finish mower doesn't handle side-to-side bumps all that well and will scalp most to all of the fire ant hills and mole hills in your orchard. The clippings are very un-noticeable compared to a side-discharge unit and you should be able to mow as tall and thick of grass as you want to with that 50 PTO HP unit of yours.
/ New finish mower needed #37
Like mo1, I also have the 6' TSC RFM. I mow 6 acres with a fair amount of weeds, and it does a good job. It looks like there is enough 'extra' space to add 3/4" or 1" spacers to the uprights. That would bring you up to 6 1/4" or 6 1/2".
Larro
328749d1374618904-600-difference-between-land-pride-040-jpg
after a really bad experience hauling my trailer an hour away to AgriSupply and finding the mower they put together for me to check out was badly damaged in shipping. And they thought that was ok. broken tires, big dent in the top of the gearbox. No, not for me. So I skipped over the next step up and spent the money to get a Land Pride. It was just in time delivery today so that I could get my field mowed before the rains came.
Mowed very nicely, exceptionally quiet mower, almost zero vibration, and it mowed everything nicely except pine needles which it left in a small windrow. Need to figure that out, and wonder if mowing in a different circular direction would help. The mower seems to stick out the left side more than the right. Not sure that is the mower or my three point hitch.
They sure did shine it up nicely for delivery, and helped me take off the phd and install the mower, and checked its operation, which they already had tested on another tractor. A nice neat and clean piece of equipment that has been thoroughly tested. Well done for the local dealer.
and boy those guys struggled getting that phd off and onto the stand. My digging is done for the year but next Spring I'll need some help getting it back on. And now the new mower goes right off and my ballast box back on so I can use the grapple this winter clearing a road into the back woods.
/ New finish mower needed #39
That Land Pride mower looks great. Congrats on the purchase.
The extra cost of that one versus the AgriSupply one will soon be forgotten. If you had bought the AgriSupply one, you would have remembered how much you "saved" every time you used it.
/ New finish mower needed #40
My neighbor had a 7' mower similar (not mentioning brands) to Daugen's with the solid tires and a very rough yard. After about 3 seasons of what I would call high speed mowing, the deck uprights were bent (torqued) inward very noticably. He finally took it to a local metal shop, had it straightened and triangular braces welded to the uprights to strenghten the frame. I think a brace between the uprights, front and rear would have prevented the issue and the balloon tires may absorb the shock enough to lessen it. Good luck and great looking rig.
UNUSED KJ K2512 - 25' X 12' LIVESTOCK METAL SHED (A60432)
UNUSED KJ K2512 -...
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
2018 F550 Bucket Truck (A61306)
2018 F550 Bucket...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
Massey Ferguson 4608 (A53317)
Massey Ferguson...
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
