RSKY
Elite Member
- Joined
- Oct 5, 2003
- Messages
- 2,782
- Tractor
- Kioti CK20S
I have posted this before but lately have seen a couple of comments about people having trouble with smells from their front loading washer. Here is the cure.
Get rid of the liquid detergent. Use only powder HE and once you get your washer odor free it will take very little effort to keep it that way.
First drain the filter which all front loaders have. It is usually located on the front left of the machine. Next pull out the detergent dispenser tray and clean the mildew out of the inside of the machine. If you have been using liquid detergent for a while this area inside your machine WILL have mildew in it. (First time my wife pulled ours out after a years use it was black inside.) Put a couple cups of powder DISHWASHING detergent inside the drum. Close the door and fill all trays up with white vinegar. Run the machine on the hottest setting for the longest time. Clean the rubber seal behind the door with vinegar or bleach. Throw away the liquid detergent. The smell should be gone.
To keep the machine odor free keep the door open slightly when not in use. Also keep detergent tray pulled open an inch or so. Most newer washers have a catch that holds the door open an inch or so. Also at least once a month run a load that you use bleach with.
Main thing is get red of liquid detergent and use only powder.
I did not figure this out on my on. A repairman told me this and we haven't had any odor since.
RSKY
RSKY
