Do You Warm Up Your Chainsaw?
   / Do You Warm Up Your Chainsaw? #1
TomSeller
Super Member
JD, Massey, Kubota, Case
Curious if people let their chainsaw warm up. I keep seeing people start them, blip, blip them and start right in cutting at full rev. I usually let mine warm for a short time. Not long, maybe a minute.
   / Do You Warm Up Your Chainsaw? #2
Long enough to get it running decent!
   / Do You Warm Up Your Chainsaw? #3
Same here.
   / Do You Warm Up Your Chainsaw? #4
Only until it smooths out and idles - maybe 30 seconds or so.
   / Do You Warm Up Your Chainsaw? #5
I start mine up, and run it at partial throttle (not idle, not WOT) for 10-20 seconds, then I get to cutting.
   / Do You Warm Up Your Chainsaw? #6
Mine doesn't like to idle at start up. I blow the cobs out of it and then it will idle. So no, I don't let it warm up.
   / Do You Warm Up Your Chainsaw? #7
I let mine warm up for maybe 30 seconds. Then I make little light power cuts for a bit like clearing brush away, limbing, etc. before making cuts using extended rpms and power. I don't know if that helps anything really but it never seems like a good idea to run a cold engine hard.
   / Do You Warm Up Your Chainsaw? #8
I go 30-60 seconds at a moderate rpm. Not sure why, just never liked putting a load on a cold engine.
   / Do You Warm Up Your Chainsaw? #9
I guess I never thought of a chainsaw as needing warmed up. I don't warm up my push lawn mower or weed eater either. I've had each for over 10 years.
   / Do You Warm Up Your Chainsaw? #10
I dont warm mine up much, start it and run above idle enough to clean up a bit then run 3/4 throttle when cutting. most people over rev their saws while they can run 100% best cutting is usually somewhere lower depending on species of wood & sharpness of chains. I keep my chains hand filed sharp & I cut at RPM where I can feel/hear the best cut for the gas buck.
M
Carnival Ticket Booth (A51691)
Carnival Ticket...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
GREEN CLIMBER P23-80 REMOTE CONTROL SLOPE MOWER (A51406)
GREEN CLIMBER...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
2017 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A52377)
2017 Chevrolet...
