Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #681
I will need to look into that HD filter. Thanks for the info
It's quite a bit taller and needs a new shroud that comes with the kit.
attachment.php
   / Tractors and wood! Show your pics #682
Most guys don't need the heavy duty filter. Some parts of the world down under have a much higher density of "dusty wood" so extra filtering comes in quite handy. I once cut with a guy who was using a Dolmar 6400. We cut all day and his regular filter was cleaner than the 440 Stihl I was using at the time.
   / Tractors and wood! Show your pics #683
Yeah, the case design of the 044,440,046,460, and now 461 offers poor filtration. I had to add a felt band around my 461 filter for milling, which creates fine sawdust. Otherwise the filter corrugations would get jam packed with sawdust very quickly.
   / Tractors and wood! Show your pics #684
The filtration on the Stihl MS 441 is awesome.
   / Tractors and wood! Show your pics #685
Good point. It's probably use specific also. Milling, lots of bucking non green logs, etc. But you are right, down here there's no way I could make it even half a day with the stock filter. The saw also seems to breath easier with the better filter.
   / Tractors and wood! Show your pics #686
Here's an interesting comparison of walnut from the same tree. I was moving firewood up to our front porch this afternoon and came across more of the old walnut I had (probably been 4 years since the tree was felled at this point).
On the right is a small piece of limb that was split very soon after the tree was felled. You can see the dark heartwood and light sapwood is unchanged, as it was able to dry quickly.
On the left is a pice of limb that was split 2 years later, as I was finishing off some scrap pieces and getting ready to mill. The heartwood and sapwood have blended to the same consistent dark color. Pretty cool to see side by side.
   / Tractors and wood! Show your pics #687
Here's an interesting comparison of walnut from the same tree. I was moving firewood up to our front porch this afternoon and came across more of the old walnut I had (probably been 4 years since the tree was felled at this point). <img src="http://www.tractorbynet.com/forums/files/owning-operating/406198-tractors-wood-show-your-pics-walnut22-jpg"/> On the right is a small piece of limb that was split very soon after the tree was felled. You can see the dark heartwood and light sapwood is unchanged, as it was able to dry quickly. On the left is a pice of limb that was split 2 years later, as I was finishing off some scrap pieces and getting ready to mill. The heartwood and sapwood have blended to the same consistent dark color. Pretty cool to see side by side.
Good comparison!
   / Tractors and wood! Show your pics #688
Good comparison!
2017 GMC Savana (A53314)
2017 GMC Savana...
Mini Plate (A53316)
Mini Plate (A53316)
2015 Ford F-350 4x4 Cab and Chassis Truck (A55788)
2015 Ford F-350...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55302)
Greenworks...
Decorative Deer Statue (A55758)
Decorative Deer...
2842 (A54757)
2842 (A54757)
