AKfish
Super Member
- Joined
- Oct 1, 2004
- Messages
- 5,419
- Location
- Alaska
- Tractor
- JD 5115M; JD 110 TLB; JD 4720; Ford 9N; JD X300R
AKfish,
A couple of you have asked me about hydraulics....I'm not very knowledgeable about hydraulics at all. What should I be looking for in terms of hydraulics? I run a 15' batwing, 21' disc, 7' tiller, 4 row planter, and 16' cultimulcher primarily. We have several cutters but none will require anything the 15' doesn't. What should I be looking for in terms of hydraulics?
The biggest disadvantage that I can see with these models is the limited transmissions. 9 forward gears is all.
Thanks,
VHORN4
Do the outer spindles on the batwing flip up independently or both together? Of course, that's either one hyd SCV or two; depending on how the mower works. IIRC, 2 rear mount SCV's was all that was available on the "early" 6D's. If that's all you'll ever want or need, OK.
Sometimes, a new tractor brings on new implements, too! 'Course it can also help with resale or trade down the road as well if there's more hydraulic couplers.
Redneckracin' mentioned pump output as well. Very noticeable working a loader compared to an M or the R models.
I'm pretty sure that JD recognizes where the 6D is a bit "short" compared to the rest of the market. As such, I believe JD has changed the transmission options on the 2015 models to 12x12 and/or 24x24 PowerReverser. And, I think you can get up to 6 SCV's, too.
AKfish
