Which Stihl pole saw?
   / Which Stihl pole saw? #31
I stopped in at my local Home Depot a couple years ago and happened to walk into the rental center part. They had one of the echo extendable pole saws for sale, the rental guy says yeah every year or two we upgrade our rental equipment so we sell off the old. They had a price on it for 169.00 I said I will take it when he rang it up he said the price on saw the was wrong ,but we have to honor the price on the sign. Long story short he sold me the pole saw for that price with a 10% military discount and gave me 9 extra chains because they don,t sharpen them they just replace them when they are rented. It is a very good and sturdy saw it always starts on the second or third pull. I do not think I will ever wear out the saw but when you go out and use it for a couple hours or so it will wear you out.
Good luck
Mark
   / Which Stihl pole saw? #32
I don't know my exact model but its the Sthil that extends. The way I look at it I can always not extend it and still use it. It has plenty of power. Like others have said, its an instrument of torture if used much more than a 1/2 hour.
   / Which Stihl pole saw? #33
I have a Stihl Kombi KM130 R power head with a pole pruner head and tiller head. It's been a pretty handy set up and the tiller is great in the garden. You might consider it instead of a sole purpose pruner. I just spent 12 hours over the weekend cutting dead limbs around the yard. One heck of a workout!
   / Which Stihl pole saw? #34
Using the harness I mentioned in post #18, I can easily put in a few hours with my Stihl HT131. Unlike other harnesses, this one will pretty much remove the total weight of the saw from your arms.
   / Which Stihl pole saw? #35
The easy lift thing looks nice, but it cost about what I paid for my pole saw used. I think I'll just take breaks instead.
   / Which Stihl pole saw? #36
I have an Echo PAS 266 quick-attach arrangement, with a pole saw attachment, and the 3-foot extension too.
--------and a brush blade that has a 7 1/4" Skilsaw blade which is the clear WINNER. The brush blade is so much lighter weight and cuts (instant and almost effortless) and cuts anything from grass to 2 1/2" diameter. And it will cut an un-supported branch ( TING ! ) where the polesaw just vibrates it. Polesaw is too heavy, it will wear you out.
As I said, I have both and the only time I use the polesaw is when there's a branch bigger than 2 1/2" or if I need a controlled vertical cut that's higher than 8 feet, but it's pretty seldom. Typically I walk the area with the skilsaw arrangement, get 98% of the work done (up to 8 feet high) then use the polesaw for a few high branches (if at all).
I would say that a carbide skilsaw blade on a brush cutter is about 10 times the productivity of a polesaw, or chainsaw, for bushes & branches up to 2" and from zero to 8 feet above ground. I have many many hours doing this work (clearing brush & clearing trails). I used the commercially available brushcutter carbide blades and cound they were too expensive and too big, and too heavy. 7 1/4" Skilsaw blade is far lighter, spins up faster, far superior, only a few bucks and available everywhere.
Physical effort, I would say that a pole saw is about 5x the physical effort of a skilsaw brush blade.
Skilsaw blade has some perilous action out there, it's probably not for everyone, but it gets far more work done in same time, produces far better results and a new skilsaw blade is $5-$7. That said there's lots of folks who ought to stay away from a polesaw too.
A pole saw for cutting near the ground is just wrong wrong wrong. It's too heavy, and too slow, cant use gravity, and you will inevitably touch the chain to the dirt then it will dull fast, becoming even more strenuous when dull. Just try it in the store (pretend) you will conclude that it's a bad idea without spending a cent.
I stopped at a Rural Farm store tonight and looked at the PAS266.
Then I started looking around at attachments, and all of them stated they were for PA 260, 261 and 265.
So I asked the kid in the area, he was lost, he barely knew how to read much less figure out the differences so He called the manager, and of course the manager said none of the attachments fit that PAS266 powerhead and blamed the issue on the Echo rep and that they will have to call them to figure out what is going on
   / Which Stihl pole saw? #37
LOL ... You are correct! The thing is not cheap. Fortunately, my wife has a rule - If the property is more work than fun, we need to sell. Therefore, she supports buying whatever tools/toys I need to keep this all enjoyable.
   / Which Stihl pole saw? #38
Does she have a sister?
My ex wife's favorite saying was
" Bob we do not need one of those "
   / Which Stihl pole saw? #39
Been reading more.... looks like the Stil is a 4 cycle, 2 stroke?
(looks like it has valves like a 4 stroke BUT, uses premix?)
Also read that the valves are plastic?? (huh?!!!!)
Looks like the Husqvarna units are true 2-strokes?
I am a big fan of Stihl but that alone might sway me to the Husky. I need to get to the dealer and see them.
Bush Hog R0-720 Pull-Behind Ripper Tractor Attachment (A51691)
Bush Hog R0-720...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
New Wolverine Skid Steer Root Rake Bucket Attachment 34'' (A53002)
New Wolverine Skid...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
MCELROY PIPE FUSION MACHINE (A52472)
MCELROY PIPE...
