Disc size guess?
   / Disc size guess? #1
DDT
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Have Kubota M6040 4x4 with loader. Have sandy soil, I think it would pull a 10 or 12' wheeled disc. Hard to find 10' in my area. Im referring to a finishing tandem disc. Off set pulls harder. Any experiences or thoughts?
   / Disc size guess? #2
Yeah, your tractor will easily pull a 12' finish disc. I have one. I pull it with my M9540 in 2wd at half throttle. Actually in the conditions you mentioned you could pull a 14'.
My disc gangs can be adjusted for more severe cut or straightened to do finish work. On all discs you can set a stopper on the cylinder so the wheels carry part of the load. With these types of adjustments in mind, your tractor will pull a much larger disc than you might think.
   / Disc size guess?
Yes I have a set and use them when needed. In my area we call them cylinder stops. Thanks for the 12 ft vote. I want to buy the correct size first time.
   / Disc size guess? #5
Worse comes to worse, you can always make a disc smaller. It might be a little harder to make it bigger, though.
   / Disc size guess? #6
William Edwards at Iowa State has a fact sheet that shows you how to calculate the required HP for various implements. It's a pdf file and I can't get a direct link to work. Google matching tractor power and implement size and the file will show up. There are also spreadsheets that you can download that will perform the calculations.
Steve
   / Disc size guess? #7
I'm with Motown, go big. Look for a 14', settle for a 12', forget a 10'.
   / Disc size guess? #8
You may be right, but I'd go with a 10' if I had the choice and that size tractor. I'd rather be able to set the disc to the most aggressive angle and bury it up to the axles, even though it would take longer to complete the job with a 10' vs. a 12' or 14'.
   / Disc size guess? #9
I used the formula in the fact sheet I referenced, and came up with 53 HP for a 10ft disk weighing 2000 lbs traveling at 5.5 mph in sandy soil.
Steve
   / Disc size guess? #10
Steve
So is that PTO HP, or drawbar HP? Unfortunately they don't publish drawbar HP much these days, at least in the size we're talking about.
2016 Kenworth T880 T/A Vactor 2112P-16 Combination Sewer Jetter Vacuum Truck (A50323)
2016 Kenworth T880...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
Great Plains Nutri-Pro NT-30 Nh3 Applicator (A50514)
Great Plains...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A52128)
Texas Post Driver...
Komatsu PC138 (A50490)
