New Holland T4030 hydraulic pump question
   / New Holland T4030 hydraulic pump question #1
msmith
West Virginia
New Holland Powerstar 75
I bought a used 2008 T4030 in 2010. I am possibly in the market for a 3 point hitch firewood processor but want to make sure that it has enough hydraulics to handle it. Specs say that it either comes with a 12.8 gpm or an optional 16.1. How can I tell which one? Called the NH dealer and they weren't sure. It came with two remotes, so I am hopeful for the bigger pump. The smaller pump is 0.8 more than the least recommended by Wallenstein but I would rather be in the middle to upper end of the specs if possible. Thanks.
   / New Holland T4030 hydraulic pump question #2
Give your dealer your serial number and ask him to run it and print the variante (build sheet) report. That will tell you which pump it has. If he won't do it or can't figure out how, PM me the serial number and I will do it for you.
Thank you Rick! I just mentioned it in passing with the local dealer, so I will hit him up with it in the morning. Thanks again.
Dealer THINKS it has the 12.8 gpm pump but says that there is always the possibility of it having a 16.1.
Why couldn't I just swap out the pump for a 16.1?
   / New Holland T4030 hydraulic pump question #5
Yep, Rick is right on. Give them your SN and they'll tell you everything about it down to what month/year it was built. CNH does a fantastic job of supporting all the brands they have purchased over the years.
   / New Holland T4030 hydraulic pump question #6
   / New Holland T4030 hydraulic pump question #7
Forgot to add, love your tractor. I came within an inch of buying a 4050 a couple years ago. I always hear good things about those models.
Thanks for the info ovrszd! May just have to live with slow and steady lol.
I had a 93 Ford 3930FWD that I bought new. Loved that tractor, but it was lacking HP for my hay equipment on the hills around here. Found this T4030 and love the ergonomics for sure. Everything is laid out nice for sure. I do believe the quality of the 3930 was a bit better though. If I ever come across a nice 5030, it may come home as a second powerplant. In the meantime, my M-I-L has one of the last 3930s made in 2wd. Some day I would like to buy it off of her. It has less than 100 hours on it so far. I keep the oil changed yearly for her.
   / New Holland T4030 hydraulic pump question #9
That would be a jewel to have for sure!!!! If anything it would suffer from "lack" of use. :)
   / New Holland T4030 hydraulic pump question #10
The GPM's can be determined by warming up the engine.
Plug a hose into one of the remote outlets and place the other end in a 5 Gal bucket.
Rev the engine to max, and then push the remote lever to max for the work port with hose..
A 12 GPM pump will pump 12 GPM in 60 sec
-------------------------------6----------30
-------------------------------3----------15
-------------------------------1.5--------7.5
--------------------------------1.0-------5 sec
A 16 GPM pimp will pump 16 GPM in 60 sec.
-------------------------------8---------30
-------------------------------4---------15
-------------------------------2---------7.5
-------------------------------1---------3.75 sec
2009 HINO 185 18FT BOX TRUCK (A52577)
2009 HINO 185 18FT...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
Toro Workman MDX Utility Cart (A51691)
Toro Workman MDX...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
1993 International 4900 Flat Dump Truck, VIN # 1HTSDPNM9PH489370 (A51572)
1993 International...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
