Buying Advice YM1700 starter, best place to buy
   / YM1700 starter, best place to buy #1
morris lipham
prattville al
kubota L185, yanmar YM1700
w:)here is best place to buy ym1700 starter? hoye has one made in Germany for about $330, other places have hitachi for about $150-180. what would be the better buy?
   / YM1700 starter, best place to buy #2
There's a seller on ebay with something like 40,000 positive feedbacks. His (new, replica) is about $100.
From him I bought the nearly identical starter for a larger Yanmar and I like it, it spins fast. Search here for my old posts on this - I'm busy outside this afternoon or I could find the thread for you.
   / YM1700 starter, best place to buy #4
Look for a small independent starter and alternator repair shop near you, Take the starter with you as they will likely recognize it and can either fix it or offer a cheap replacement (from China).
The part numbers dont mean much except to the dealer.
Starters are used on a wide variety of engines built by different companies.
I have given the same advice to other forrum members and it worked out well for them.
Dave M7040
I looked at cheap starters on ebay & amazon, they don't look like my ym1700 starter & they don't tell you how many teeth. I am leaning toward the Hoye starter, all the parts I bought from them are first rate.
   / YM1700 starter, best place to buy #6
I had my Ym2000 rebuilt in Apr. 2011 72.75$. 90day Guaranteed. Same starter as the 1700. Most any Auto Elec. shop will rebuild it. Not the first complaint to the day and having the original starter is a big plus. If it can't be rebuilt/repaired then I would spend the money and replace it. Save yourself a few Hundred Bucks.
Thank you, I will try that first, will save a lot of $$$$
   / YM1700 starter, best place to buy #8
I had upgraded my Nippon-Denso on the JD850 (aka YM2500). It was the older technology of solenoid that died. Got an Offset Gear Reduction starter (OSGR starter) for under $100. It was more powerful too. Didn't have to worry about letting the stater cool down after 10 seconds of cranking. I could crank till the cows came how.
So, depending on the OE maker of your Yanmar starter, there could be a newer technology replacement at a better price too.
This is the one I had gotten. Amazon.com: NEW STARTER FITS JOHN DEERE EXCAVATOR YANMAR ENGINE 3TN78L 171353-77010 AT110818: Automotive
Nippon-Denso makes the OE 1.4kW for the tractors and the 2.0kW for Toyota, Mazda, Nissan, etc. I had found a good cross-reference chart on the web that matched the splines, teeth, mounting holes and opening, and wire hook-up. It was basically a drop in upgrade.
Many of our Yanmars originally started with the old school VR (voltage regulators), now places all over the web along with Hoyes and Fredricks offer the solid state upgrades too. Wish they did that for the starters, the prices would be a better deal.
   / YM1700 starter, best place to buy #9
Ok, I looked up my old post. I bought the starter Bmaverick described above, 2.0kw of torque compared to the 1.4kw original on my YM240. Same vendor except via ebay. I see rareelectrical now has over 70,000 positive feedbacks. None of his few negative feedbacks that I reviewed relates to product quality, only shipping screwups, (ordered wrong part and expensive restock fee, etc) and those are below 1%. In summary a quality source. The starter I ordered there has been in service four years now, and is like new.
I think this is a good solution for a YM1700.
Thanks, that's why those replacement starters on ebay & amazon look different than OE. I will certainly check them out.:)
2005 Ford F-350 4x4 Service Truck with Crane, VIN # 1FDWX37P55EB97537 (A51572)
2005 Ford F-350...
2016 Ottawa Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, 33,000 ... (A52748)
2016 Ottawa Yard...
2013 FREIGHTLINER M2 ROUSTABOUT TRUCK (A52472)
2013 FREIGHTLINER...
2014 KOMATSU PC490 LC-10 CRAWLER EXCAVATOR (A52576)
2014 KOMATSU PC490...
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
