CDN Farm Boy
FYI - open circuit means that when you actuate the hydraulics oil is pushed into the side that you want to use, i.e. lift side and the opposite side of the cylinder has the pressure released and allows the oil to flow back to the reservoir
Sorry but I disagree with you. Your description is how any hyd system works.
Open center refers to the design of the pump that it is variable displacement depending on load. Closed center uses a fixed displacement pump that is always trying to move fluid and is subject to over heating issues if the fluid has nowhere to go which in a closed center system gets accounted for somewhere downstream (I know my way around an open center system pretty decent thanks to JJ and others on here but not a closed center system)
