I am in a quandary for selecting a tow vehicle rated at 11k # or greater. My heavy towing needs are only occasional and most of the time the truck will be inside with the tractor once our new place is built and all of the outside landscaping, etc. is completed, will not be a daily driver and would be my last HD vehicle purchase. Ideally I would get a good used 4WD, 6.5' bed, extended cab, 3/4 ton, gas engined with 4.x gears, ~ a 2008 model. But in my area these are still pretty expensive. The 3/4 ton pricing led me to seriously consider new 2015 1/2 ton Ford Ecoboost or GM with the 5.3L engine, as unloaded fuel mileage would be a lot better, it seems. And at this point I am waiting for the 2016 Toyota and Nissan diesels to see the light of day for price, fuel mileage and towing capacities.
This post actually concerns the unloaded fuel mileage of modern diesel 3/4 ton trucks. Yes I am aware a HD diesel truck is overkill for my uses. But if I can get a good one for a "reasonable" price relative to a new HD 1/2 ton truck, that gets good enough unloaded fuel mileage, this might actually be a viable option. I do have my eye on a low mileage, certified 2008 LT Duramax for a decent price. But it will probably be gone by the time my mind is made up.
I initially was very interested in a Ford 3/4 ton, 6.0L PS as the truck and pricing fell into line with my needs. However, further investigation really scared me away from the post 7.3L Ford diesels due to all of their designed-in issues. But there are now some 6.0s on the market at used truck dealers that have ARP head studs, which indicate they had blown head gaskets, but should not have this issue again. However, I am still very leery of these as overall this engine has been trouble prone. The GM Duramax seems like a good, reliable option, as does the Dodge Cummins. And I do not want to initially buy into the high mileage diesel maintenance costs.
What kind of unloaded fuel mileage do you get with your diesels? Although I imagine in this class of truck, they may seldom be used unloaded.
