Pilot bearing removal question
   / Pilot bearing removal question #11
Kosmo
How about a picture so we can see what you are dealing with. Many of us have replaced these bearings, and may be able to help, but show us what your dealing with.
   / Pilot bearing removal question #13
Thanks for the replies, but like I said the grease blew out the flimsy retainer and now I get no hydraulic action because the new grease just flies out between the bearings. I'd try a slide hammer but that again means buying the whole shindig of over $40 and all the ones I see also say 1/2" minimum id. Although that harbor freight hammer is cheap enough it might be worth a shot if all other ideas fail. I've got no welder so that approach is out. I thought of the anchor bolt idea but was thinking there is not much room below the bearing, maybe a half inch. Has anyone ever tried using something like clay or silly putty? Seems like the greater viscosity might slow down leakage thru the bearings now that the thin metal retaining ring is gone.
Is this a ball bearing?
   / Pilot bearing removal question #14
I tried removing my post but couldn't. What I had posted was for a brass pilot bearing.
   / Pilot bearing removal question #17
   / Pilot bearing removal question #18
Well well ! What about wet newspaper and a 12mm bolt ?
Since it appears it has to be assumed it is a ball bearing this is a good stab at it. ... Another possibility would be a corn starch suspension in place of grease. If things like that dont work and a puller is too much there are many other nondestructive ways. They all involve making something.
The most gross would be to break the bearing cage and take out the inner race and balls. Gives a lot more room to work to remove the outer race.
   / Pilot bearing removal question #19
Grease has always worked for me but that has always been on bushings, not a ball bearing.
What I would do is as larry suggested and break the inner race and let the balls out. Then you are dealing with just the outer race inside a 28mm bore. Lots more room to work. Then I would either grab my slide hammer with hook, or lay down a bead of weld around the outer race right inside where the balls normally would be. After that weld cools down, the race will just fall out.
   / Pilot bearing removal question #20
He said he doesn't have a welder.
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
1997 INTERNATIONAL 8100 4X2 WATER TRUCK (A50458)
1997 INTERNATIONAL...
2004 INTERNATIONAL 4300 BOX TRUCK (A51222)
2004 INTERNATIONAL...
