TomSeller
Super Member
OK, I think I under stand your question now. Well besides plastic I have used pre bought wooden wedges and wedges made on the spot out of the face cut wood. While blocking firewood I have used a steel splitting wedge in the past. Can be hard on the saw chain :laughing:.
As far as doing the job best and holding up to the abuse the plastic ones are my choice by far. Their angle is right so they don't spit (sp) out on you when under pressure and some have a roughened surface to help hold even better. After you hit them with the saw a couple times you can remake them with a belt sander. The only things I don't like is that they seem to expensive for plastic even though they are worth the price and if it is very cold out, 0* F or so, you have to be careful starting them and hit them with a square blow because they might break off where the plastic is thin.
gg
I have some old steel ones that are nearly the same shape, I was just surprised how much easier to use the plastic ones were. I think they nailed the angle and obviously the light weight helps a lot. Plus my steel ones got used somewhere along the line as splitting wedges so they are mushroomed out a little to the point they don't go in and out of my back pocket easy like plastic ones did.
