Bush Hog 297 or Landpride RCF 2784
   / Bush Hog 297 or Landpride RCF 2784 #1
leebritt
brentwood, tn
none
Looking at 7ft rotary cutters. Can get the Landpride here locally for $2900 and the Bush Hog for $3200 I think. Any thoughts? JD 4720 with Cab and bucket. Cutting about 25 acres with some brush up to 2" or so. Thanks!
Lee
   / Bush Hog 297 or Landpride RCF 2784 #2
Landpride is a very good unit, but again so is Bush Hog. But for $300 I would go with the Landpride.
John
   / Bush Hog 297 or Landpride RCF 2784 #3
John
I should add that I have a Landpride RCR2672 and it has been a tough unit that has been abused for 5+ years and has held up well.
   / Bush Hog 297 or Landpride RCF 2784 #4
Not much difference at all. Both good, almost identical specs.
BUT, according to bushhog the 297 is a discontinued model, and the BH27 is the replacement. Also has nearly identical specs. Might be some incentive to get a better deal on the 297.
If I were you though, I'd overlook the 7' single spindle cutters and look to an 8' twin. You tractor will handle it better. Something like a BH2008 ro LP2596. You give up some cut capacity, but once the first mowing is done, as long as you keep it maintained there is no need for a heavier duty cutter unless you plan on cutting commercially IMO
   / Bush Hog 297 or Landpride RCF 2784 #5
Or buy a 3008 and have the HD capacity. FWIW, saving the $300 to buy a Landpride will get eaten up in blade and blade bolt replacement costs over time. Bush hog blade and bolt prices are far better than Landpride's (or Woods, for that matter). I agree with bargaining hard on the leftover BH.
   / Bush Hog 297 or Landpride RCF 2784 #6
I agree with this. That 7' single spindle is heavy and hangs WAY back there. The JD 4720 should have the PTO HP to run it, but that's a lot of leverage hanging off the back of the tractor.
   / Bush Hog 297 or Landpride RCF 2784 #7
I bought my 7' SQ84T for just a tad less than $3,000 and it is a very capable piece of equipment. It does not have near the length that a single spindle bushog has and it is wider on the right side of my tractor by about 15". That comes in pretty handy around a tree line or fence line. I am very pleased with it. Not trying to sell a brand just commenting on my experience.
   / Bush Hog 297 or Landpride RCF 2784 #8
That SQ84T is the only 7 foot multi-spindle cutter that I know of. I seem to remember it's rated for 1.5" brush, which is a little lighter duty than the 2008 8' cutter I think, but it's still a very capable cutter. If I was going for a 7' cutter, that would be the one I'd pick.
Yeah, I was interested in the SQ84t too. He has one of those for $2900 I think. He also has a 2008 and possibly a 3008. What's the opinion on the SQ84? Is the offset desirable or not? I like the thought of a 7ft dual spindle. I can probably handle the 2008 just fine and I probably am not going to be cutting much over 1.5" anyway. Might just go for the 2008.
TROYBILT TB51BP GAS BACKPACK BLOWER (A51248)
TROYBILT TB51BP...
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
ECHO CS-3510 CHAIN SAW (A51248)
ECHO CS-3510 CHAIN...
1838 (A51248)
1838 (A51248)
