Engine Ticking noise at startup?
   / Engine Ticking noise at startup? #1
jodebg
New Hartford, CT
Kubota B-2650
I have recently noticed a ticking noise after start up.
Similar sound to a valve lifter.
Kubota b7800 30HP.
It does not happen at every startup and goes away very quickly.
Any ideas of suggestions?
   / Engine Ticking noise at startup? #2
Why don't you post the engine make and model.
Walt Conner
   / Engine Ticking noise at startup? #3
How many hours on it?
When was the last oil change done and what grade of oil are you using?
525 hrs.
Lst oil chandge was late Fall of 2014 @ 495 hrs.
Redline brand full synthetic oil
10w 30 as called for in the manual
Also use Redline Diesel fuel additive
   / Engine Ticking noise at startup? #5
Any chance you were using non-synthetic before the most recent oil change?
I once had something similar happen...nearly new machine running non-sythetic for the first oil change or two and then switched to full synthetic. After the change I would sometimes hear a light ticking (valve lifter) for a few seconds after start up. I think the synthetic was simply draining more fully, depending on the position the lifters were at when they stopped, and that would cause the ticking on startup. I kept running the same oil in it, and it never caused a bigger issue for the 14 years I had it.
If something similar is happening to yours, it could be the difference in temps now that it has warmed up, compared with when you did the oil change and thought the Winter and Spring....now that it's warmer, the oil will flow better, and drain better.
Prior oil change was also Redline full synthetic. At that time I used 5w-40.
The latest oil change I used 10w-30 also full synthetic.
   / Engine Ticking noise at startup? #7
Is it a factory oil filter? If not, does it have an anti-drain back valve? That is usually a flap of silicone rubber that acts as a check valve to prevent oil from draining back into the pan when engine is off. Cheaper filters use materials that don't seal as well.
Symptom of a missing or bad anti-drain back valve is a ticking or bearing rap that goes away a few seconds after an engine starts. That means something is running dry without oil briefly. No bueno!
If that's not it, I wonder if maybe you should just go back to the heavier 40 oil.
Kubota oil filter!
   / Engine Ticking noise at startup? #9
Any signs of sludge in the oil when you change it? It could be a oil port is partially plugged and delaying the oil reaching the lifter.
Not enough hours on it to build up to much sludge but could have been contaminated by another source.
   / Engine Ticking noise at startup? #10
Since the new 30 weight is lighter than the 40 it replaced, it could be draining more completely out of the lifters. I would expect to see a difference between when the engine has sat overnight, versus shut down for only a short period of time. If that's what's going on, you'd expect the ticking to only be when the engine has sat for a long time.
A bad filter anti-drain back valve would be more likely to cause valve lifter noise that last longer, and likely be accompanied by a bearing rap. Also, it depends on where the filter is located...if it's low enough in the system the oil won't drain into the pan.
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
UNUSED LANDHONOR 82" FORK EXTENSIONS (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR LHR-DFP10 DSL FUEL TRANSFER PUMP (A54757)
UNUSED LANDHONOR...
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A55787)
2025 GIYI GY-X39F...
