3point hitch problem
   / 3point hitch problem #1
MisterMan
Alabama
MF2605
Hey Everyone,
I am in need of help with my MF231.(not 231S)
For the last two weeks when I try to lift hay with hayforks the 3-point hitch doesnot hold where I place it, it either goes up or down on it's own. I have to constantly hold the control lever to keep it somewhat in a fix position.
My question for you all is there an adjustment for the 3-point hitch to stay fixed at what ever position you lift it too?
your suggestions will be more than appreciated.
MisterMan
   / 3point hitch problem #2
:welcome:
To TBN MisterMan from Northwest Alabama. What part of Alabama are you in?
mdorange, I am a little bit south of Montgomery, Alabama...:)
   / 3point hitch problem #4
You use position control not draft control ?
Draft control never used. It's in up position.
   / 3point hitch problem #7
I have a brother-in-law that lives in Wetumpka but he doesn't have a tractor so we call him the black sheep of the family.
mdoange that not far at all from me. Lol he might be a smart man no stress of farming...lol
Hey TimberJackRob, the lever it self moves on its own and the hayfork arms move also.
the control lever doesnot stay fixed. let me say this also, it will stay fixed "sometimes".
here is a example of the issue: I was using tractor with box blade to level pile of gravel, would pull up straighten up begin backing up, box blade set to height I needed, start backing up before reaching pile maybe ten feet away box blade would start
creeping down, then I would have to grab control level and lift box up again.....that makes sense? I am completely lost on this issue. I was hoping that there was an adjustment screw or something on the tractor I could set to control lifts.
thanks,
MisterMan
   / 3point hitch problem #10
You shuld have somthing like this on your lever
2008 CAT 305C (A53317)
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
Push Mower (A55973)
Push Mower (A55973)
2019 Chevrolet Silverado 2500HD Crew Cab Liftmoore 2700AR 1 Ton Crane Service Truck (A55973)
2019 Chevrolet...
2004 MANAC 48FT CURTAIN SIDE SPREAD AXLE TRAILER (A57880)
2004 MANAC 48FT...
Toro z turn (A56859)
