Garage door torsion spring winding bars
   / Garage door torsion spring winding bars #11
I found an old pair of tire irons were the perfect size
paul
   / Garage door torsion spring winding bars #12
I always just used two large phillips head screw drivers since I already had them in my tool box. They are long enough to twist the spring easily and wont bend.
   / Garage door torsion spring winding bars #13
I borrowed a set from the guy I bought the springs from. Crazy but out here in California they can't sell you the springs to DIY unless your a licensed contractor. 29 1/4 turns is about right. Be careful. That's alot of tension.
   / Garage door torsion spring winding bars #14
I repaired a spring loaded door recently where the spring had broken. One of the things I found was that one had to stretch the spring axially when tensioning it since it expanded in length when you lower the door and the tension on the spring is increased. I used a ratchet strap pulling against one of the attachment points for the vertical guides and only needed to stretch it about 1-2". It does not sound like much, but since the coils otherwise touch each other, it can generate enormous force if it is constrained.
I also suggest you experiment with different amount of tension compared to what the manufacturer recommends. I was able to back off the tension quite a bit and it reduced the load on the door opener substantially. It runs much more quietly now compared to the way it was originally installed. If you can comfortably raise or lower the door by hand, then it is going to work slick with your garage door opener. All one needs is to mostly counteract the weight of the door when it is vertical.
   / Garage door torsion spring winding bars #16
A large overhead door company, should have winding bars in stock.
Last set I bought, was only around $10.
Remember, to try not to bunch the springs tightly together, when you are done winding them. Before you tighten the screws, if you try, you will find you can pull the cone slightly away. This spreads the spring just a little, giving it more room for it to twist, without binding.
You also want to set them "hot", which means about 1/4 turn tighter than neutral. Within 6 months, the spring will wear in, and the door will be balanced.
I also suggest anyone installing a new door, or springs, upgrade to a larger size springs. It's only a few bucks more, and they will last longer.
   / Garage door torsion spring winding bars #17
I bought new springs last yr off E Bay.. The springs came with adjusting rods.. I have used 1/2'' rebar in the past
   / Garage door torsion spring winding bars #18
Ace Hardware sells the winding bars here.
   / Garage door torsion spring winding bars #19
Don't forget to oil the tension springs at least once a year, some recommend twice a year. It lets them do their thing easier and they will last longer.
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2017 FREIGHTLINER...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
