So I just noticed this zerk near the front axle ...
   / So I just noticed this zerk near the front axle ... #1
aarobyn
Skiatook, Oklahoma
TBD
So I just noticed this zerk under the tractor. At the front axle, and along the PTO shaft? The picture is actually upside down - didn't notice that until I added it.
I've not been adding grease here (Kubota L3400, 150 hrs).
Screwed, or not screwed?
Grease it, or leave it alone?
Thanks for the input!
attachment.php
   / So I just noticed this zerk near the front axle ... #2
Grease it , it's the bearing for the pivot point on your front axle.
   / So I just noticed this zerk near the front axle ... #3
AND, probably the hardest working grease joint on any tractor.(and I'll bet the most often overlooked)
On my tractor I used 1/8" pipe and fittings to bring the zerk fitting to one side for easier access.
   / So I just noticed this zerk near the front axle ... #4
Not sure about your model, but mine has a square head bolt opposite the zerk from the front. You take it out so greasing is easier.
Otherwise, if u have a loader, I would recommend raising your front wheels off ground to help the grease flow.
   / So I just noticed this zerk near the front axle ... #7
I've seen instances where $8 worth of grease applied to a zerk in that location over 5 years would have prevented a $3500 repair bill.
   / So I just noticed this zerk near the front axle ... #8
I have L3700SU, which is very similar to your tractor.
My manual does not list this zerk, however I grease it once a year when I grease everything else.
The manual does list a zirk and a breather bolt at front of the front axle.
   / So I just noticed this zerk near the front axle ... #9
Why do you grease so often?
   / So I just noticed this zerk near the front axle ... #10
grease it and grease often every 3-4 months
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2003 PETERBILT 330 MINI DUMP TRUCK (A55745)
2003 PETERBILT 330...
2013 Nissan Juke SUV (A55758)
2013 Nissan Juke...
2013 Ford Escape SUV (A55758)
2013 Ford Escape...
Skid Cropmaster Baler Twine (A50775)
Skid Cropmaster...
Danuser 12" 3pt. Post Hole Digger (A50775)
Danuser 12" 3pt...
