CNC Dan
I think they mean not for highway use. IE: not D.O.T. rated.
All good points, y'all are right on this one with me.....
So, I found a brand named draw-tite hitch pin that looks just like the one I'm using from farm and fleet, but look at the price! https://www.etrailer.com/Hitch-Accessories/Draw-Tite/58388.html
That's the kind of expense I can't justify, even if it doesn't have the disclaimer.
Tongue wall thickness is 1/4 and receiver is 3/8" thick wall. Totally hear what you're saying, but this application doesn't require extensive analysis to determine it's not going to shear under normal use. But, specing a pin that says "not rated for towing" and then let's say it gets rear ended and shears and there's some complication with that, then the lawyers see what you did and bingo, you lose - whether it had anything to do with the issue or not.
That pin I gave the link for is for a 3" x 3" hitch. Those hitches are rated in the 25,000 lb range, but here we are just towing 8000. So I know we have a much larger pin than we need, it's supposed to be rugged. Comes down to the legal thing.
That first pin, though it doesn't have much of a pedigree as far as material goes, has the right price and doesn't say "not for towing". Also comes from a trailer shop, so what else do they think you would do with it? Would prefer yellow zinc chromate for corrosion resistance but till I find one without a disclaimer, this ought to work.
Funny I didn't find that, I reference etrailer all the time for lights and jacks and stuff. We even buy a few odds N sods there.
Thanks to all.
CM
PS Someone mentioned about the farm/fleet being for farm work - well I'm telling ya, there's no way we're stressing these pins anywhere near the hurt a tractor pulling any implement would put on it. Just silly legalese.
Yes. It may not get as much heavy s strain on it as a tractor but a truck also goes much faster. Going 5-10 mph towing a trailer and hitting a pothole is different then 50+mph
May i ask you. How much are you making off of these trailers?? You can't afford a pin that is rated for your tow?? If it were me i wouldn't care if i make $100 or $10,000. I would want my customers too be safe not be responsible for injury or death because a pin wasn't rated
