Diesel Exhaust Burns Eyes
   / Diesel Exhaust Burns Eyes #1
cartod
Northern, West Virginia
JD 4066, 1023
My 1972 Deere 820 tractor has been burning what smells like raw fuel. It burns my eyes when Im backing up and I can taste raw fuel. The tail pipe is down low for orchard use and Id like to leave it there. It just started doing this after an overhaul which did not include new injectors. Any help much apprectiated.
   / Diesel Exhaust Burns Eyes #2
Were the new injectors pressure tested before installation????
   / Diesel Exhaust Burns Eyes #3
Was the injector pump pressure increased by accident during the overhaul? If the injectors were good and not replaced as you say it sounds like the pressure was increased dumping too much fuel in the cylinders.
Is it a big job for me to decrease pressure and see if that fixes?
   / Diesel Exhaust Burns Eyes #6
My guess is that the injection timing is off. There is not enough time for the fuel to burn before the exhaust valve opens. In addition the engine develops less power therefore the governor will governor overfuel the cylinders.
   / Diesel Exhaust Burns Eyes #7
You'd have to check with your dealer as I'm not familiar with how yours is set up. Or it could be the injector timing as Ladia mentioned.
   / Diesel Exhaust Burns Eyes #9
That is a fine looking tractor.
   / Diesel Exhaust Burns Eyes #10
It's more than likely the pump, i had a 74 model identical to yours & that's what the problem was, i've been wrong before though.
Ronnie
UNUSED FUTURE SZYMJ HYD STUMP GRINDER (A51248)
UNUSED FUTURE...
UNUSED CFG HANG-ON PALLET FORKS (A51248)
UNUSED CFG HANG-ON...
2016 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2016 Ford F-150...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
UNUSED JCT HYD AUGER (A51248)
UNUSED JCT HYD...
JD 1814E LOT IDENTIFIER 264 (A53084)
JD 1814E LOT...
