Asphalt driveway damage / repair
   / Asphalt driveway damage / repair
It doesn't appear to be distressed enough for that to be the case. The pavement you have is keeping the base from mixing with the silt below but it isn't strong enough to avoid cracking when a truck goes over it when the base and subsoil is saturated in the spring.
When building new an eight inch layer of clean sand does about the same job as a geotextile fabric and often costs less. Which to use comes down to the cost of excavating out the extra eight inches or the strength and water level of the soil below.
Thanks. One last question: I'm sure the heavy trucks sometimes wander right to the edge or off of it, which could easily start cracks at the edges that would then grow inward. Can we do anything to insure against that method of damage? Does it help to have the finished surface above the grade by a couple of inches?
Or is a properly built driveway/road going to be equally durable out to it's edge?
   / Asphalt driveway damage / repair #22
A typical road calls for the base to be full thickness 6" past the edge of asphalt. This helps support the edge of the asphalt. The sod is held down approx 1" below the top of the asphalt to avoid trapping water on the roadway, while at the same time avoiding excessive roadside dropoffs.
   / Asphalt driveway damage / repair #23
I work for a civil engineering company and have density tests on roadway. We never test the edge for the roadway for density because there is nothing for the roller to roll against. If there was a curb or something to restrain the edge of the asphalt as the roller rolled along the edge, then the density would be good, but with out something to restrain that edge, the asphalt just squishes out and you don't get good density.
That suggests the road should be extra wide - if the heaviest vehicle runs to the edge of the driveway, it's not going to hold up either. And once a crack starts it always grows. I think that may be a factor in my driveway problem.
At the end of the day, I think I'll have in mind to get quotes for work knowing 1) the heaviest vehicle load 2) the widest heavy vehicle and 3) expected life. It seems nothing will be comparable unless those are considered. Then if I'm having stuff delivered I can specify a reasonable limit - more axles, less in the bed, etc and be much more aware of when the soil conditions are most risky too. At this point there is extensive cracking and I think the cracks are growing regardless of soil condition.
I'm not a civil but a mechanical. I don't expect to review the designs but at least I can hope to communicate a sufficient set of specs. Or maybe dig deeper - this is a huge investment - if there is good reading material you suggest I'll go bone up on it.
   / Asphalt driveway damage / repair #25
Six inches is cutting it a little close considering the experience level of the average road worker today. A better plan is to place your base a foot wider on each side of the pavement edge and compact it as well as the available equipment can do it. If your in cut that is no problem as the old ground will hold against the compactive effort. In fill, four to one side slopes or flatter are the best bet, but if you have to go to two to one then they add a foot to each side to help hold against the compactive force and to provide a strip to hold the guard rail posts.
   / Asphalt driveway damage / repair #26
I would download your local city/county/dot specifications for driveway Construction. They probably don't regulate what you do outside of the ROW, but they will have standards of how they do it in the ROW. If you have a lot of truck traffic, consider using the spec for "commercial driveway". In Florida, it would be 6" of 3000 psi with wire on compacted subgrade, if using concrete; or 1.5" of Sp-9.5 on 10" of LBR100 limerock, compacted to 98% modified proctor (100% of standard proctor).
Edit: residential asphalt would be 1.25" of sp-9.5 on 6" of rock.
Re-edit: both specs assume a firm subgrade or native ground,
   / Asphalt driveway damage / repair #27
Actually Dgeesaman I think your driveway is in pretty good shape for it's age and could last several more years with no attention whatsoever. If you are fussy and want it to look perfect then it comes down to how much you want to spend on perfection. Being a cheap SOB I'd probably drive on it as is for years until you needed to fill pot holes with patch to drive over it without spilling your commuter cup of coffee.
   / Asphalt driveway damage / repair #28
One thing to keep in mind is asphalt is considered a flexible pavement. Its designed to move up and down. When it move up and down to much in too short of a span, thats when it cracks, or as the driveway ages, it gets more brittle and starts to crack.
   / Asphalt driveway damage / repair #29
Good thread because I've the same problem developing.
I've a driveway/parking area about 180 yards long and about 1,000 sq yards in area (SWAG). It's in Mississippi thus USUALLY very little frost problems, it's fairly well sloped so little standing water. But I am getting areas that are "cracking", mostly around the edges.
Chip and tar, what we call Chip and Seal or "slag" will flex with the movement and is a good choice if, and only if, there's people around who can do it cheaply. I think for 50 lane miles, we where paying $2.40/ square yard, and a 1" thick over lay runs from $5-7.50/sy (large scale quantities, home owner price is probably double that).
The Grafco crack sealer is a (roughly) half rubber half asphalt that will seal cracks and also hold them together. It had to be heated in a kettle or heated crack sealer machine (approx 400-500 degrees), but there are some more consumer friendly products. If the entire (or a good percentage) 1000 lf of the drive is alligator cracked, the chip seal is a good option, and works well with an eventual asphalt overlay.
Did you mean Crafco crack sealer? Request Rejected
Is that much the same as the "tar blocks" mentioned below?
I have a 1200' driveway that was alligatoring on the edges sometimes up to two feet in. Our situations are different in that no dump trucks or gravel trucks come on the driveway, just my 16,000# camper and my dually. This was neglected for years. I have a pretty decent base, I think so that wasn't a concern for me.
As suggested by someone on this site, I went to Lowes and got tar blocks, heated then to melt them on a 40-60,000 BTU burner, put that in something called a pour pot, then poured the liquid on the bad areas and my wife used a long handled ice scraper to smear it into the cracks. It is a rubberized darker color than the rest of the drive but works in my situation where light traffic is involved.
My ideal fix would be to pick up the to two inches and start over, but this is cheaper, although may not work in your situation. Cost for me was 75$ for the pour pot, $350 for tar, $100 for LP.
Are "tar blocks" the same thing as what I used to put in the hot tar kettle when I used to work flat roofs? We would then mop it on the felt.
That is a good way to get to the bottom of the problem. I would only add that instead of adding gravel I would add just inch and a half minus concrete stone. The mix that comes out of the grinder already has too much sand in it and adding gravel which is a good mix of sand and stone doesn't have any extra stones to give to the ground up sand.
I've spread on as much as 0.17 tons of stone per square yard (a layer three inches deep) and had them mix it in with the second pass of the reclaimer. Overlaid with three inches of hot mix 2 binder 1 top and you get a road stronger then many of your state roads. Don't forget the drainage if needed though. Water is the worst enemy of a road.
What I had feared doing was to section off an area, dig it out, put down base, repave on a retired do-it-myself basis.
I figured getting a contractor to do it would be big bucks I could spend elsewhere (grapple, QA, log arch :) )
   / Asphalt driveway damage / repair #30
Crafco is the brand name of the crack sealer
The tar blocks at lowes are the same as roofing tar.
The OP has a new driveway that was severely under designed for the loads it carries .
Can you post pictures of the Mississippi driveway.
If your driveway has been functioning and is showing age, it will be a different repair method
   / Asphalt driveway damage / repair #31
It might be Crafco; but it is not just block asphalt, it has a high amount of rubber. The machines I've seen use electric or propane heat and it's much hotter (400-500) than regular asphalt concrete (300-325 degrees). You clean the cracks with compressed air, then pour and squeegee it. If you need to open to traffic immediately, you can spray with "detack".
   / Asphalt driveway damage / repair #32
The driveway for the OP is two years old and showing alligator cracks and rutting. As roadway , it would rate fair to poor condition .
Repairs will be cheaper if the base driveway remains in fair condition.
That's slightly reassuring - my personal standard is I hate potholes. The cracks don't bother me but chunks of asphalt coming is disrepair in my book and once cracked and the cracks begin to widen, the potholes are not far behind. Snow removal, icing, etc become a big problem. I don't mind the look of professional patch repair and sealants provided they are functional.
In a few years we'll be past some major initial loans that helped get us into our place and a big project like this may be possible. It would be great to capitalize on low asphalt prices now but I don't have a cash stash to be that flexible. That said, when the time comes, if asphalt is still cheap I'm not above taking a loan if the cost of interest beats out the likely increase in project cost.
I'm trying to understand all of this now because it went from no cracks to a few cracks to many cracks with grass growing thru in a matter of two years. The rate of degradation is a bit alarming. It reassures me to understand what's going on, and so this knowledge is very helpful.
The driveway for the OP is two years old and showing alligator cracks and rutting. As roadway , it would rate fair to poor condition. Repairs will be cheaper if the base driveway remains in fair condition.
My driveway is probably 10 years old, based on the bleaching. The cracking began two years ago. There were no cracks when we bought the property.
   / Asphalt driveway damage / repair #34
Why would you be afraid of that? sounds like an excellent project for someone with some time and a tractor.
   / Asphalt driveway damage / repair #35
Cash flow is always a consideration. A emulsion and sand seal is a cheap treatment that won't fix any ruts etc. but will slow down the rate of deterioration. At the least it would give you a couple of years to consider you're options and let you pay down those huge loans you bit into to buy the propery in the first place.
Unless you're planning on flipping and reselling it in a couple of years the condition of the drive isn't really that important as long as you can drive all the way to the garage. :)
   / Asphalt driveway damage / repair #36
Yes, it had been functioning and is showing age.
<snip>
I feared/dreaded it because it looks like a long, slow, HOT project. I only ran tar kettles for a few years in Vermont, where a HOT day was when it hit 90 degrees F in the sun. In Mississippi this summer it was routinely 97 degrees F in the shade. Plus there are many other things I need to do that I've got some experience doing.
I've never used hot tar/asphalt on the ground. Usually 50 to 100 feet up.
   / Asphalt driveway damage / repair #37
To repair driveway, you will need several things.
1a dump truck to haul asphalt. Shoveling asphalt before it cools is not fun
2 method to excavate existing driveway
3 roller to compact asphalt.
The asphalt will need to be compacted in layers . Getting patch flush with surrounding driveway will be trial and error process. Most patches done by inexperienced crew are rough
Rough patch is still better than a hole
If your driveway is aging with some cracking, sealing the driveway makes sense.
   / Asphalt driveway damage / repair #38
It looks like the classic narrow pavement break-up. If you don't want the edges breaking, go at least 12 feet wide. If you know heavies will be driving on it, go to 14' and crown the gravel underneath so the edges are thicker.
OP...how wide is it?
It goes as narrow as 9 feet. 10-11 in some areas. That's narrower than I thought.
   / Asphalt driveway damage / repair #40
The neighbor that is a excavator and put in my drive said 12' is the min for the pavement because of edge break-up. I have the propane truck and septic pumper for heavy trucks. He recommended 14' wide for the base(4" rock w/ 3/4" over) at 10"+ deep, rolled, to support a 12' wide drive.
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A60429)
2017 KOMATSU...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
JLG 600 AJ SKYPOWER BOOM LIFT (A60429)
JLG 600 AJ...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
FORD 8530 TRACTOR (A58375)
FORD 8530 TRACTOR...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
