Bx23 turf tires and chairn
   / Bx23 turf tires and chairn #1
twinponds
I want to put snow chains on my bx23 turf tires--I cant tell if i need spacers or not, or if so, how thick. Anybody running chains on bx23 turfs without spacers?
   / Bx23 turf tires and chairn #2
Simple- measure clearance between the inside, and top, of your rears tires and the fender. If you have 2" or so, you should be good. Different chains have different requirements, of course. I bought a set of chains for my L3400's front wheels, which are likely similar sized to your rears... If you are interested, I will sell them cheap. Measure your circumference, and PM me??
   / Bx23 turf tires and chairn #3
The above poster is correct. Two inches is about the required space you will need for chains. I put chains on BX-25's with both turfs and R4's without spacers. It was a tight fit, but they worked. In this shot, the tires were R4's.
   / Bx23 turf tires and chairn #4
I have 4-link chains on my BX2200 with turfs and 2-links on my BX2660 with turfs- no spacers need on the rears of either.
   / Bx23 turf tires and chairn #5
They fit on by BX 23 with my bar tires, but its a close tolerance. Spacers give a little more room. If you don't use spacers make sure you have good tension on the outside so the can't migrate out from the tire and grab one the levers underneath. You can guess why I know about that. I use spacers and keep em tight now. Not a worry now
   / Bx23 turf tires and chairn #6
i have 2 link vbar chaine on my bx 1830 and they fit good put rubber tie down to keep your chaine tight
   / Bx23 turf tires and chairn #7
I use chains on My BX23's R4 tires. No problems. On and off in minutes.
   / Bx23 turf tires and chairn #8
How about loaded tires instead? Turfs and loaded tires and no need for chains.
I like the loaded tire all season, because they double as a counter weight for heavy bucket loads.
Just a thought
   / Bx23 turf tires and chairn #9
Sometimes, when you are dealing with ice, or icy snow, chains are the ticket to moving. Turfs alone, no matter how heavy the tractor above them, can spin on ice.
   / Bx23 turf tires and chairn #10
Just for reference ..... I have a T1030 NH which is about the same size as a BX.
I bought new chains for the rear loaded tires (R4s) for usage when I put the 52" blower on the back.
In two years I have yet to need them. They're still in the box.
UNUSED FUTURE MINI SKID STEER PALLET FORKS (A51248)
UNUSED FUTURE MINI...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A53426)
2020 INTERNATIONAL...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A53473)
JOHN DEERE ROW...
2005 International 4300 Bucket Truck (A52377)
2005 International...
2009 ARROW BOARD MODEL - 9069 (A51247)
2009 ARROW BOARD...
