Yes the dealer says its a damper , they haven't changed one in 15 years . They recommend pb blaster on the pivot shaft . Tough place to get to . I tried wd 40 didn't help . I adjusted one spring but not much !/4 inch or so . It doesn't look like it has much it can do . I pulled on it hard but it didn't bring it back much . It sticks when the tractor is not running also . I guess I will try tightening the spring a lot , spray with pb blaster . It seemed to happen overnight or suddenly .I may remove damper to see if it has any affect . They said something about a plastic bushing on shaft so that it would not need greasing by design.
