Running a welder on a generator for field use?
   / Running a welder on a generator for field use? #1
dntfxr
north Louisiana
Ford, LS
I've got a project coming up that will require welding away from any power sources. I do have a generac generator and was wondering how it would work to run something like a 200 amp stick inverter, or a Millermatic 211 mig off of the generator. Has anyone tried this? Or should I bite the bullet and get a Gas powered welder?
   / Running a welder on a generator for field use? #2
I run my 130A wire feed welder (Lincoln 175 with flux core wire) off of a 3000W generator all the time. Can't run it at full power but I can run it plenty hot enough to weld up to 1/8" material. A bigger generator would let you run it at a higher power output.
   / Running a welder on a generator for field use? #3
I run my 130A wire feed welder (Lincoln 175 with flux core wire) off of a 300W generator all the time. Can't run it at full power but I can run it plenty hot enough to weld up to 1/8" material. A bigger generator would let you run it at a higher power output.
300 watt gen set running a welder??
SR
   / Running a welder on a generator for field use? #4
DEPENDS, how big is the generator and how many amps does the welder require??
SR
   / Running a welder on a generator for field use? #5
if its hit and miss use I wouldn't buy a gas weldor...those lil inverter machines don't draw much jam..worse case scenario you could drop down to 3/32 rod and only need half your 200 amp potential...again it depends on your generator size but if its a decent 5k plus I wouldn't worry
   / Running a welder on a generator for field use? #6
I run my Miller 211 and my inverter stick welder quite often off my Miller 250 Bobcat. It works just fine off that power source.
Sent from my iPad using TractorByNet
Ok thanks guys, that's what I was thinking. It's a 6500w continuos 8000w surge with a 30amp 240 plug so I should be good to go. I didn't know if the type of power it makes might screw with the welder or something, glad that's not an issue. The little Lincoln 110v mig I have won't quite be enough for the material I'm welding and my old Dialarc is just too big. I've been thinking about getting a new welder, now I have an excuse lol. I'm looking at maybe a Millermatic 211, or a AC/DC stick/tig combo like the Alphatig 200 or the new Lincoln square wave 200. Any recommendations on a small portable unit?
   / Running a welder on a generator for field use? #8
SR
Or a typo, 3000. I don't think they even make a 300W generator so that it was a typo should've been obvious.
   / Running a welder on a generator for field use? #9
I think have seen little ones at Harbor Freight.
   / Running a welder on a generator for field use? #10
I have a Miller 210 and when I bought it I emailed Miller and ask if it would work on a generator and was told that it would.
I had a 200 AMP Miller Portable that I have since sold.
I now have a Wacker 5.6kw generator. I haven't tried it on the welder BUT, I have run my whole house including computer and TV/sound system for 12 days continuous after a close call from a hurricane with no problems.
I would guess those electronics would be more sensitive that a welder.
2016 Ford F-150 4X4 Crew Cab Pickup Truck (A55852)
2016 Ford F-150...
2022 CATERPILLAR 315GC EXCAVATOR (A52707)
2022 CATERPILLAR...
Frontier FM2015 (A53314)
Frontier FM2015...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2017 Ford Escape AWD SUV (A55758)
2017 Ford Escape...
16FT box truck (A53424)
16FT box truck...
