Found one thing I don't like about Mahindra
   / Found one thing I don't like about Mahindra #21
If you do not replace the cable terminals, you are wasting your money on a new battery. My 3016 terminal corroded completely apart. I replaced both positive and negative with clamp type terminals.
   / Found one thing I don't like about Mahindra #22
Reeltime
When I went to purchase mine it was loaded up on the trailer and ready for my truck to hook to it... "Bought the whole kit-and-caboodle; trailer included".
I drove another one on the lot to get acquainted with the controls before I left. Hopped in mine that was loaded to 'redistribute the load' on the trailer and - nothing....not even a click. Salesman made it right and pulled one from the tractor that I just demoed and installed on mine. Well it lasted 2 years, and it kicked the bucket as well. There was corrosion on the terminals as well. Winter and high compression engines will make a battery work hard; these batteries that come from the factory typically have low cranking amps to boot.
I didn't fuss too much because "if Mahindra was to skimp on quality, a battery is where I would want it"... Something destined to perish from age or use anyway. I sucked it up and bought a higher cranking amp battery from Napa and slobbed a ton of grease on the terminal ends, yes slobbed is the correct word; meaning that what little I had left on my fingers got wiped all over the top of the battery as if it were a rag.
A 'little grease' does not go a long way in preventing corrosion, but a Lot of grease will prevent any corrosion. I encapsulate every battery terminal with a ton of wheel bearing grease on all my vehicles as well. Stuff works like a charm!
   / Found one thing I don't like about Mahindra #23
^ well said.
Thanks I was just venting but I have disconnected terminals cleaned them globed grease on the terminals
Sent from my iPhone using TractorByNet
   / Found one thing I don't like about Mahindra #25
Mahindra did not have a "recall" per se but they did warranty the battery and cabling from any damage. My dealer was even willing to grab my tractor back to repaint the area that got corroded. I used "Chassis Guard" first then painted up the battery box over that. I was a little out of warranty but the dealer held my hand on the battery anyway. There was a ton of these Exide batteries that had porosity at the posts. I'm wondering if Mahindra or whoever got a deal on a bunch of batteries of questionable construction back then.
   / Found one thing I don't like about Mahindra #26
Bought my tractor in May 2005. I replaced the original battery last month after nearly 10 1/2 years.
   / Found one thing I don't like about Mahindra #27
I still have the OEM battery in my 2008 "2015"
   / Found one thing I don't like about Mahindra #28
We have identical tractor as Mahindra (I think as M 3016) made by TYM. We bought it in 2004 and it still has original battery.
   / Found one thing I don't like about Mahindra #29
I think you mean by Mitsubishi. They call theirs which is identical to the 3016 (understandably since they made the 3016) an MT28. As I understand it, your tractor has a Kubota engine but my 3016 has a Mitsu. Tym does make their 4010 and 5010 tractors which are a bit larger tractor than the 3016..
   / Found one thing I don't like about Mahindra #30
yup the 3016 is a Mitsu.
1271 (A50490)
1271 (A50490)
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
2015 Dodge Charger AWD Sedan (A50324)
2011 Nissan Rogue SUV (A50324)
2011 Nissan Rogue...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
