Sawyer Rob
Super Member
Sounds like some good upgrades...
Thanks,
SR
Thanks,
SR
it sure does but I find f you are not going to process the wood for a year, a lot of the mud will wash or dry and break of. Still there is grit embedded into the bark. That is why I like the trailer approach or cut the rounds and load them in a carry all. Doesn't take long for a chain to get dull cutting through grit.I have a dumb question...I see skidders are really common in Nth America, and can see they would be great for getting the log to where you want it. But wouldn't it pick up a lot of dirt as you drag it along the ground, and therefore blunt your saw really quickly when you came to cutting the rounds?
I've included pics of the examples I presently skid in with my cut and was wondering if these smaller grapples would handle this type of multiple stem hitch.
Arrow, my grapple opens to about 46" and is what's called a bypass grapple and it closes down to about 5". One side of the grapple passes through the other allowing for a wide gripping range, but I do have troubles with multiple stems. Those 2 in your pic would proly work fine, they are straight, limbed and will "gather" nicely. I do have problems some times with multiple stems because I take the (trimmed down to about 4") whole tree out for firewood and this can keep the logs from bunching up tight in the grapple and it seems to add additional dragging resistance. One real nice benefit is the log is mostly off the ground and stays clean and is not nearly as hard on your skid trails or roads, and depending on the size of your log, it can be completly off the ground with the butt end of the log under the grapple at the hitch. This is similar to the "heel" on a log loader.
