T8 flouresent bulbs
   / T8 flouresent bulbs #11
T-5's are are being put in many commercial space as a efficiency gain.
FWIW, the number behind the "T" is the size (diameter) of the bulb, in 1/8"ths. T-5 = 5/8, T-8 - 1", etc.
All I know is the older I get, the more light I need:D
Interesting. Thanks.
   / T8 flouresent bulbs #12
I am slowly replacing all of my T12's with LEDs. Every time that one fails, I replace the fixture with a new LED fixture.
How is that working out for you for brightness? I have 6 fixtures, double two foot T12s cool whites in my workshop with drywalled 8 foot ceilings. I use it but is not like daylight. I looked at Costco double four foot LEDS for $30 but chickened out because of the unknowns.
yes these are new t8 fixtures in my new shop, just seems they are not as bright as the T12s in my old shop, guess i will have to watch what i buy at the hardware store, before i just got whatever t12 bulb was the cheapest but if i do that now with the t8's they are not as bright.
   / T8 flouresent bulbs #14
When I changed my T12 fixtures to T8's I bought a case of T8's. 30 tubes to a case.
To me they are much brighter than the T12's. The tubes I bought are:
F32T8/TL741 Alto II.
Light output 2800 lumens
Color rendering index 78
Color temperature 4100K
Life 30,000 hours
   / T8 flouresent bulbs #15
Could be a few variables coming into play comparing different buildings, ceiling height, wall and ceiling finish, light output per square foot, etc
Personally I like the 6500k in t8
   / T8 flouresent bulbs #16
At the hospital I use SP 3500 for general locations and SPX 3000 for areas warm and cozy...
The difference is so pronounced people swear the areas are painted different colors and they are not.
   / T8 flouresent bulbs #17
And to lead this off the OP's original question - if you have to get new ballasts you can swap in new T12/T8 form factor LED's that don't need a ballast.
I've a bunch 8' T12's with failing ballasts that are wired through conduit and it seems easier for me to clip the ballast out and put in new LED tubes with minor rewiring than it is to replace everything.
We have been replacing t12 ballasts with t8 ballasts, and then putting in led tubes... dunno if that is cost efficient or not, but those are the directions from mgmt.
   / T8 flouresent bulbs #18
Dont sound cost effective to me to install a new ballast and THEN a LED tube. Just get rid of ballast all together and buy the right LED tubes. One less thing to fail and consume energy (make heat)
   / T8 flouresent bulbs #19
I would definitely be in agreement with this. The whole concept of the LED tube that makes use of the ballast is easy no tools retrofit of existing fixtures, but putting in a new ballast and THEN putting in an LED replacement tube seems dumb to me.
   / T8 flouresent bulbs #20
Maybe they have something besides the standard 110-277V supply voltage. At work I have 277V light fixtures (thousands of them). As the T12's go bad I've been replacing the ballasts with electronic ballasts for T8 tubes. The T8 ballasts run at roughly .33 Amps compared to .60 Amps for T12. I too have to abide by what management says to do when replacing or upgrading lighting. Exit lighting has already been replaced with LED fixtures.
I believe that when most (but not all) people become managers or part of Administration and get that sheepskin to hang on the wall they lose the common sense sheepskin it replaces.
Scag Mower (A50324)
Scag Mower (A50324)
230112 (A53422)
230112 (A53422)
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
