Forks Looking for Combination Pallet Fork for 3PH & FEL
   / Looking for Combination Pallet Fork for 3PH & FEL #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I am looking for a pallet fork that can be used on the 3PH and the FEL. Is there such an attachment?
   / Looking for Combination Pallet Fork for 3PH & FEL #2
I've thought about adding three point pins to my existing set of SSQA forks, but haven't done it yet. I think that would be the easiest way to go. I've also considered just buying a set for the three point, so I could carry a pallet on the front and one on the back at the same time. I hear Agri-supply has them for a pretty good price. I've also considered a three point forklift mast. There's a used one available locally for around $500. That seems like a good option since you could put stuff up high, but I suppose you lose some lift capacity due to the weight of the unit.
Good luck with your search, and let us know what you figure out.
   / Looking for Combination Pallet Fork for 3PH & FEL #3
I would just add some pins unless carrying two pallets is important. I have been wanting to do the same thing since my 3ph lifts 3,700 pounds.
   / Looking for Combination Pallet Fork for 3PH & FEL #4
I just sold my 3pt forklift. It had a similar or better range than my loader. But with the extra weight of the forklift (500lbs maybe) my 3pt couldn't end up lifting much more than the loader & forks (IBC tote a little over 1/3 full of water). The forklift didn't even flinch lifting things, but my 3pt stopped lifting. I didn't want to push it & break something on my tractor. It lifted a ton or so & guess it might have been able to lift 2 or so, but my 3pt stopped lifting around 3/4 ton. I probably could have gained a bit taking off my quick hitch, but I'm lazy & like the ease of the quick hitch.
Bought it for $200, put new hoses on & ended up selling it for $300. Really haven't seen many on Craigslist in the past year or so. There is another for $900.
   / Looking for Combination Pallet Fork for 3PH & FEL #5
Did your forks have a mast like a forklift?
   / Looking for Combination Pallet Fork for 3PH & FEL #6
   / Looking for Combination Pallet Fork for 3PH & FEL #7
How well did that work? I have been thinking about building something similar. I have an old forklift mast laying around.
   / Looking for Combination Pallet Fork for 3PH & FEL #8
Could have origionally been off a forklift for all i know. It was chained to the quick hitch ontop because my welding for a temporary quick hitch compatible toplink bracket sucked.
   / Looking for Combination Pallet Fork for 3PH & FEL #9
Once you get the weight of the mast off the ground the capacity of the lift depends on the mast hydraulics matched to the tractor PSI and GPM.
I have been looking for a 4K mast but so far no luck. I would would probably put it on the front in place of the FEL using the QH unit for front blades. I am also looking for ideas so will be following this post. I like the point of not adjusting the angle constantly like using bucket forks.
Ron
   / Looking for Combination Pallet Fork for 3PH & FEL #10
If I did it I would want to hook it up on the backhoe subframe to reduce the risk of busting something. The problem is I can't figure out how to get it hooked up without using another tractor to lift it up. I also thought about putting it on the loader and resting the mast on the ground, but I was afraid it would still put too much pressure on the loader.
2017 JOHN DEERE 437E KNUCKLE BOOM LOADER (A52705)
2017 JOHN DEERE...
2022 Wacker Neuson LTV6 Towable Light Tower (A55851)
2022 Wacker Neuson...
2021 Kubota KX033-4 (A53317)
2021 Kubota...
2013 Jeep Grand Cherokee Laredo SUV (A55853)
2013 Jeep Grand...
UNUSED FUTURE 44" CAT305 EXCAVATOR RAKE (A57193)
UNUSED FUTURE 44"...
Wooden Rocking Chair (A55853)
Wooden Rocking...
