Converting Rain Water to Drinking Water
   / Converting Rain Water to Drinking Water #21
Nah.....you're using too hot water....or it's those cheap Vietnamese sheets... :D
I wish, Mate. Top of the line 1600 thread count "bamboo" linen. I never had the problem whilst living on the mainland on 'town water'.
However, you could be right on the hot water temp... I had to replace the hot water heater a couple of years back so, perhaps the 'warm' setting on my washing machine is too hot due to the hot water supply.
   / Converting Rain Water to Drinking Water #22
...I had to replace the hot water heater a couple of years back...
How hot do you need it??:)
   / Converting Rain Water to Drinking Water #23
Always drink upstream from the herd.
   / Converting Rain Water to Drinking Water #24
   / Converting Rain Water to Drinking Water #26
If you catch rain water off the roof, the gutters would be full of bird poop, especially if there are many trees around. Starlings by the hundreds and many Robins and other birds perch on the gutter edge and sometimes take a drink for themselves. Such water would definitely need to be treated with some kind of antimicrobial agent...........just sayin'. I've drunk that city water as well as many city dwellers who live into a ripe old age............It can't be that unhealthy even though it would taste different that other "natural" sources of water......Detroit being a possible exception.:D
   / Converting Rain Water to Drinking Water #27
Detroit's water is fine.... its what Flint was using before the fiasco. They switched back to Detroit water.
   / Converting Rain Water to Drinking Water #28
I've set up a couple off grid water catchment systems for folks. They are some complex pre-filter systems (Vortex filters) that separate out the first few gallons from the roof and gutters, those having the most leaves and bird poop, but we simply used a 6" PVC T turned sideways....the upper part being the inlet from the gutters, the lower part being a 'trap' that catches the first few gallons (you can extend that with pipe as much as you want to trap in terms of gallons), and the side part of the tee leading into the tank.
A hose bib is mounted in the trap part, and left cracked open so it drains the tee slowly between rains and leaves it ready to receive water at the next rain. Also a plug clean-out at the bottom of the trap lets you remove collected stuff from time to time.
After the first few gallons, the tee fills (hose bib is running real slow) and spills over into the tank. You still want to filter and sterilize tank water. We used a 12v pressure pump, a T in the line with one line going out to water garden/etc (unfiltered), the other to a whole house filter with a 5 micron element, then a UV sterilizer light rated for 5gal/min. You end up with real clean water.
   / Converting Rain Water to Drinking Water #29
Not exactly. Seems there is questionable levels of lead in the water of quite a few Michigan water supplies (and Ohio). What happened was they had Detroit water and Detroit Water and Sewerage adds phosphates to the water which coats old lead pipes and keeps them from leeching. Flint switched to Flint River water which was more corrosive and flint never added the phosphates so the pipes started leeching lead. Then They switched back to (Detroit) water but the damage was already done.
Who is to blame? You decide. If the Flint water department had added the phosphate in the first place, there would have never been an issue.
   / Converting Rain Water to Drinking Water #30
We have a high level of calcium in out well water which is not conducive for washing equipment or cars so I got 2 empty IBC totes from the shop and I run the gutters on the shop into them with leaf strainers in line and use that for equipment washdown. Works real well. We used to have a cistern in the basement for roof rainwater but we never drank it, Just used it for washing clothes and bathing. Rainwater is excellent for that. Sometimes I wish we still used it instead of a well.
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
2012 PROCO 130BBL VACUUM TRAILER (A53843)
2012 PROCO 130BBL...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
