Converting 5093E 3pt hitch stabilizers to square male / female telescoping type
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I hate the Threaded Adjustment stabilizers & wanna convert to square telescoping type like on a 5425 that you simply drop a pin in correct hole.
You guys have a link to a parts illustration ?
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #2
From jdparts.com
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #3
Looks like Zebrafive hooked you up!!!
My Kubota came with them. I converted my Ford to them using CNH's online parts listing to find a replacement.
Not sure why any manufacturer would offer a 93HP tractor with stupid thread adjustable stabilizers.......
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #4
With a quick hitch, like the iMatch, the stabilizers are not adjusted very often, if ever. Might be one reason...
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #5
Yeah possibly. Just seems cheap to me. I run a QH on my Kubota with telescoping stabilizers and like you said, never use them. But I'd still think I got slighted if it had thread adjustable stabilizers.
I even converted my JD 2210 to telescoping stabilizers.
No disrespect, but I don't care for the quick hitch setup as it moves your attachment back farther away from your tractor.
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #7
Your preference is fine... but I'd never go back.. and have half a dozen iMatch compatible attachments. None of which are a problem "too far back". It's all of 6 inches.
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #8
JD offers a kit now to replace the chains on the 5E limited and is optional on the new 5e's. I guess enough people complained (including me)
   / Converting 5093E 3pt hitch stabilizers to square male / female telescoping type #10
Yes. That needs to be considered. In my case I may switch 3pt attachments 2 or 3 times in a day. The QH takes all the frustration out of that task. Especially with TnT. I pay little attention to where I set an attachment down or how level it is. And I pay no attention to the placement of the attachment anymore.
I shot a video a couple years ago hitching my Kubota to a JD 10' 3pt brush cutter, powering it up, shutting down and unhitching. I accomplished that in less than 2 minutes using the QH. I then shot a video hitching my Brother's smaller Kubota to a 6' 3pt brush cutter, powering it up, shutting down and unhitching. Took me 14 minutes using 3pt with telescoping stabilizers.
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
JOHN DEERE 850J LGP DOZER (A50854)
JOHN DEERE 850J...
2010 TROXELL 140BBL TRI AXLE VACUUM TRAILER (A50854)
2010 TROXELL...
Set of Ag R4 Wheels and Tires (A51039)
Set of Ag R4...
Ram 4x4 Pickup Truck Bed (A49461)
Ram 4x4 Pickup...
2016 MACK CXU613 DAY CAB (A51222)
2016 MACK CXU613...
