kubota nut
I've just purchased a 1953 Ford Jubilee for $1800. Runs good, has some oil leaks, almost sure it needs.a a front seal replaced. Does anyone know exactly what is a live PTO on a jubilee model.
It doesn't have a live pto. You will need an overrun clutch on equipment such as a rotary mower or the mower will push you forward. A live pto is the same on any tractor. That is a tough tractor, I had one for years. Without a live pto the mower will act as a flywheel and turn the pto shaft. This will turn the rear wheels and continue to move the tractor until the mower rpm is 0. The overrun clutch only clutches in one direction. With it installed the flywheel action of the mower does not affect the tractor. It is able to freewheel. This is probably not the best explanation on record but hopefully understandable.
It doesn't have a live pto. .
My understanding of what a live PTO is that you can depress the clutch and the PTO doesn't stop. I thought I knew this, am I wrong? Often times the TPH not working on a Jubilee is from a bypass valve sticking or I think a seal blown. I have not worked on a Jubilee for 35 years so my memory is a bit foggy. Ed
