Inside house temp - do you decline over the winter?
   / Inside house temp - do you decline over the winter? #11
SWMBO likes it about 74'. since we heat with wood it isn't a big deal. This time a year we usually don't have a fire, and it is a little cooler around 68.
   / Inside house temp - do you decline over the winter? #12
It is 75 degrees and climbing as I'm getting a good fire going. Very cold outside today.
   / Inside house temp - do you decline over the winter? #13
Humidity might have something to do with it -- in the dry part of winter, 60F feels a couple degrees colder than 60F in the spring when humidity is higher.
We put in a whole-house humidifier and I noticed it makes the house a lot more comfortable in winter.
Humidification helps with comfort during the winter months for sure. If you have Forced Air, a nice By-Pass Humidifier is a great add-on. Humidity will help cooler temps feel much more comfortable in the house. As for our house I put in a new Honeywell WiFi Tstat and really enjoy if it feels cool I can turn up the heat from my phone while sitting on the couch LOL:thumbsup:.
   / Inside house temp - do you decline over the winter? #14
The house stays at about 80 all winter, wifey stays in shorts and a tank top all winter. :D We have an indoor "gasser" wood boiler for heat. When you work outside all day, 80 is delightful to come home to and warm your core.
   / Inside house temp - do you decline over the winter? #15
We set the thermostat at 70 during the day and 67 at night in winter (those were both negotiated with my wife -- can't go any cooler without risking divorce -- she's a southerner and I'm a Yankee) . When we run our fireplace, it will boost the first floor up to 72-73 by the end of the day, which makes my wife very happy. I agree, it feels good when I come in from outdoors, but if I have to do any projects indoors, I end up sweating the whole time.
   / Inside house temp - do you decline over the winter? #16
My wife has a CPAP machine so going cold at night was a problem. I found out I could get a heated hose for her which made it much better.
   / Inside house temp - do you decline over the winter? #17
We keep upstairs bedrooms at 66 or 67 in winter.
   / Inside house temp - do you decline over the winter? #18
Dang you guys lucky. We have been stuck to heating with space heaters all winter because of house under construction and shortage of money. We were happy to get 50s most of the winter. Now if it goes over 40s outside we shut one heater down
   / Inside house temp - do you decline over the winter? #19
I keep the house at 68 all winter. During the summer I open the windows on opposite ends of the house after sunset and pull in the cool night air with two fans. By morning the house is usually down to 62-65 and will climb to 68-70 by sunset.
   / Inside house temp - do you decline over the winter? #20
We have a programmable thermostat. It heats to 70 about 15 minutes before the alarm clock goes off. Then once the wife and boy leave it drops back to 62. About 30 minutes before they normally get home it goes back to 70. At 10pm it drops to 67 at night. We both like it cool to sleep. Since I work from home to cooler temps help get me outside. And I can bump it up for lunch or if I'm doing inside work. We cut about a half a tank of propane off the winter heating bill with it.
In the summer it kicks to 80 when empty and then to 75 for wife's arrival home. Then at 10pm down to 72 for sleeping. Then stays at 72 for the morning routine. Also helped with summer power bills.
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
2024 JOHN DEERE 6155M LOT NUMBER 9 (A53084)
2024 JOHN DEERE...
