Need a cell phone app for tracking field work?
   / Need a cell phone app for tracking field work? #1
Springfield, Missouri
2004 Fendt 209 P, 2014 Massey Ferguson 5612, 1998 John Deere 5510N
Hello,
I was wondering if anyone knows of a cell phone app that tracks tractor position in field. I use a pasture sprayer that has a 36ft. wide coverage. But I would like to more precisely spray such that I don't miss areas or double spray. Does anyone know of a good cell phone app that you could have track your position in the field with a 36ft. coverage? Thanks all.
   / Need a cell phone app for tracking field work? #2
Accuracy of cell phone GPS is at best 10 feet, and is more like 15-20 feet under normal conditions. To me, that is too much error band on something that's 36 feet wide.
   / Need a cell phone app for tracking field work? #3
Farmlogs has a upgrade that will do it but it is $$$$$$$$. I have been trying to find one for a while, nothing that doesn't require expensive equipment and service subscription for a app that I have found. Nothing free is going to work.
Maybe a real good GPS would be better.
PS. I put flags out and drive straight to them when I can. Miss some spots and overspray others in the odd shape places. Go back with UTV sprayer for missed places.
   / Need a cell phone app for tracking field work? #4
As s219 said, no phone GPS is going to have better than 3 meter accuracy. Doesn't matter what software is run on it.
   / Need a cell phone app for tracking field work? #6
You can get high precision with an external antenna with Bluetooth that connects to your phone.
To get less than 2.5 meters accuracy you will have to dig deep in the wallet. For spraying applications, I don't really think anything on a smartphone is going to give the accuracy needed to use as a guide for areas covered with a Bluetooth setup. Neither review had a moving test, all where points only and took several minutes to lock on to satellites. A tractor needing to move at a consistent speed while trying to follow a track that may or may not be locked on or up to 10 feet +- is kinda like milking a bull. Don't think you will get what you started after! LOL-
Seriously-
The setups for auto-steer tractors are accurate to within inches and not meters (yards). You got to be a BTO for that kind of setup. I have been thinking about getting a single foam marker under the sprayer so I can at least tell where the tractor was on the last pass. Maybe just get rig a removable 27' boom and use it with foam on each end and still have the broadcast head for those tight places
My Boomless Rig
27' boom
Foam Marker Kit
   / Need a cell phone app for tracking field work? #7
Half The ones from the site I listed had accuracy of 1cm to 60cm. How accurate do you need?
The phone is just for the mapping software. The GPS antenna transmits to your phone viable bluetooth.
You save cost in having the phone already. The GPS antenna is the important part.
Once you get a first time lock with any GPS device it doesn't take minutes after that. Only the initial setup takes a few minutes.
Phones are less accurate because they need to lock fast and they estimate you're traveling on highways not in Fields.
These devices are for highly accurate field applications.
   / Need a cell phone app for tracking field work? #8
Those were pretty expensive. I barely make enough over inputs and mantanence to cover taxes and utilities. I was basing my opinion on ROI and for that accuracy, lot better options to get the job done.
JMHO
   / Need a cell phone app for tracking field work? #9
As others have said you will not get the required accuracy from a Cell phone GPS. Take it from someone who took part in developing the technology. You'll have to spend big bucks to get a GPS device with the accuracy you need for what you intend to do and it won't be included in a cell phone. You can probably find something much simpler with sufficient local accuracy to do the job you want for a lot less money. Maybe some sort of a laser based device.
   / Need a cell phone app for tracking field work? #10
The Trimble ez guide 250 can be found for less than 1k and will do what you want. It is not differential and accurate enough for precision planting but works great for spraying. I have one on my tractor. A cell phone even with an external antenna isn't going to cut it.
   / Need a cell phone app for tracking field work? #11
Comparing Bluetooth GPS Devices | Fulcrum
That is true, and I have tested devices with 20cm accuracy in conjunction with my iOS app. However, the response time is SLOOOOOW. It could take up to 10 minutes for the GPS hardware to lock in to position with 20cm accuracy. Generally, any of the sub-meter accuracy devices are going to be slow like this. For farming/row-cropping, it would never keep up with the speed of the tractor (even as slow as tractors go).
   / Need a cell phone app for tracking field work? #12
Those aren't GPS antennas. They are complete separate GPS's that provide their data to other devices over bluetooth. Many of them also require other services to achieve the accuracy above that provided by phones. Read up on Differential GPS, RTCM and SBAS.
   / Need a cell phone app for tracking field work? #13
They make a dye to mix into the spray that marks the area that you just sprayed. I seen it at TSC
   / Need a cell phone app for tracking field work? #14
I know this doesn't have anything to do with apps the OP was looking for but my cousin uses this dye and it works. He uses a blue and it puts a temporary tint on the ground and you can see exactly where you've sprayed. You just pour it in at the prescribed amount on the bottle, it mixes with whatever you have in the tank and "paints" you a path. Quick, simple, and accurate. I believe you can get different colors also he uses blue.
   / Need a cell phone app for tracking field work? #15
My cousin sprays some odd shaped fields and some of them are small is one of the reasons he uses this tint. On a large parcel a foam marker would be more be economical.
   / Need a cell phone app for tracking field work? #16
Update on my above comments: Just talked to my cousin and using a dark brown fertilizer mix with the blue tint is hard to see on a hay field or pasture that has greened up already. I asked him about the different colors and he replied he didn't know of different colors. ? Have to do some research myself on this stuff.
   / Need a cell phone app for tracking field work? #18
Oh. Spray dies bring bad memories. That **** is nasty. Dies the tank and all lines. We always used a pink or blue when we sprayed water sensitive paper for nozzle test. It works. When working on the sprayer several tanks later your hands and clothes would be pink. Roundup it the worst as it'll pull it out of the tank plastic. Liquid nitrogen would pull some out also. It'd take almost a year to get that die out.
Stick with a foam marker system. Or learn to judge distance off your last tracks. That's what I do but I've also sprayed several thousand acres with foam markets too.
Measure it out and add a sticker to the ROPS or somewhere. When that it lined up with your last tracks your X feet from them. You do have to allow for the roll of the land.
thanks all for the great feedback. I'll keep looking for what is out there.
Steve
   / Need a cell phone app for tracking field work? #20
I have an app on my phone to record my bike rides. Just for grins, I used it the other day for brush-hogging our prairie. Here's what I got:
Looks like I missed a couple of spots but I didn't. As others have said, the accuracy isn't the best. I also have a Garmin computer that I use on the bike more than my phone. Maybe I'll try it next time to see if it's more accurate.
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2001 PETERBILT 379 (A58214)
2001 PETERBILT 379...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
2016 Ford F-550 Venturo HT40KXX 3 Ton Crane Mechanics Truck (A59230)
2016 Ford F-550...
