Time to powerwash the vinyl siding .
   / Time to powerwash the vinyl siding . #1
kevin37b
mansfield,Il
john deere
North side is green again . What is a good presoak before blasting ?
   / Time to powerwash the vinyl siding . #2
I am following this one with great interest.. Have the same problem..I don't have a solution
   / Time to powerwash the vinyl siding . #4
I just finished and used:
Home Armor
E-Z House Wash
Mold Stain Remover
Bought at Lowes.
Shop Mold Armor 56-fl oz Liquid Mold Remover at Lowes.com
Let it soak a few minutes and rinse. Reading the cleaning instruction online for my paticular vinyl it said no more than 1500 psi and shoot in a downward direction, that's why I just attached a hose to the nozzle on the bottle. The cap has a Clean/Rinse/Close nozzle.
Siding looks new.
   / Time to powerwash the vinyl siding . #5
Home Armor
E-Z House Wash
Mold Stain Remover
Bought at Lowes.
Siding looks new.
I think I am going to give that one a try. Thanks.
   / Time to powerwash the vinyl siding . #6
Try many combo over the years not much luck,I'll give txdon mixture a try.
   / Time to powerwash the vinyl siding . #7
I have used Jomax siding wash with great satisfaction. Wish I had discovered it sooner, it saves a lot of time. It is a concentrate that gets mixed with bleach and water and can be applied with a garden sprayer.
Amazon.com: RUST-OLEUM 60104 Jomax house cleaner and mildew killer: Home Improvement
jomax is AWESOME.. - you really dont need the pressure washer - i sprayed the siding with a small hand held pump sprayer..
BUT be warned - IF you spray above your head, where the mist falls back on you and you inhale it.. You will get a horrible sinus chemical burn.. BUT a trip to the dr to get a steroid nasal spray will fix it.. UNTIL you do it again trying to reach the upper portion of a 2 story house... LOL
   / Time to powerwash the vinyl siding . #8
21 years ago I sided my house with vinyl siding. Good friend of mine hooked me up with the product. He said, "there's two things that are necessary when buying vinyl siding. A reinforcement fiberglass rod enclosed in the siding to prevent bulging. Siding manufactured with a mold/mildew resistant chemical." He got me siding with both. I have no bulging. I have no mold/mildew. I have no color fading.
Sorry I didn't help with the problem. Just wanted to pass on my luck in having a great friend to guide me. Maybe someone looking at siding their house can benefit from it. :)
   / Time to powerwash the vinyl siding . #9
I started listening to a radio show on Sunday mornings. Gary Sullivan I think. He seems to know a lot about home maintenance and seems be a big fan of a product called "wet and forget" (or something like that). From what I hear you don't even power wash...you spray it on and wait a few weeks (apparently it takes a while). You can google his show...he takes calls if you have any questions.
   / Time to powerwash the vinyl siding . #10
I use a cup of powder laundry detergent, big squirt of dawn dish soap, and about 2 cups of pool shock (12% bleach) mixed in a 5 gal bucket with water, then feed into the pressure washer soap injector. Spray it on, let it sit for a minute, and hose off. Do not need high pressure to rinse, which is good. That is the worst thing for a house. Never use a high pressure nozzle directly on your house! I use the soap nozzle to spray the soap on, then use a "2nd story" nozzle to get water up for rinsing.
Unused Delta Crash...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
72'' power rake (A53421)
72'' power rake...
Titan PDG3200 Gas Powered Post Driver (A52377)
Titan PDG3200 Gas...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
