Jabonee
After seeing a few threads about mounting bolts coming loose and blaming the dealer I thought I'd chime in and remind/point out there is a service interval for retorquing mounting hardware. It is in the operators manuals. look close. It can be hard to find. I highlight the manuals for my customers. Interval is usually every 10 to 20 hours for the first 100 hours. Then every 100 hours or so after that. I suggest not using loctite. The bolts are not coming loose,they are stretching. I do many first 50 hour services. I always find a few mounting bolts loose. The units that come to me for follow up service I've found that after the 2nd or 3rd service/retorquing, the bolts have stretched to there max and are not coming loose. Basically,check the hardware as specified. Check more often if your a heavy use owner.
