How is this a safety device??
   / How is this a safety device?? #1
jymbee
Upstate, NY
Massey 1652, 1949 Farmall H
Like a lot of (most?) mower type tractors, our John Deere X748 diesel has a seat safety switch installed that requires someone to be sitting on the seat for the mower to operate. So ok, I can see how that could be considered a safety system. Falling off or just getting off with the blades engaged could present a risk in some situations. My personal choice was to overridden that system.
But how is the system that requires the operator to pull/push/lift some kind of button/lever (lift lever on our X748) to back up while mowing a safety mechanism? Or perhaps there's some kind of mechanical consideration I'm not aware of? I haven't tried to circumvent that particular "feature" yet but am considering it as I just can't see any downside to doing so. It just seems like an unnecessary step (and does work that well on our tractor presently).
Am I missing something?:cool:
   / How is this a safety device?? #2
Its supposed to keep you from backing over someone (somehow). IMO, the Cub Cadet system (where you can either push the button each time, or put the key in a different spot and press the button once per startup) is better.
Aaron Z
   / How is this a safety device?? #3
There have been children backed over with the blades running, thus the liability on the mfg's part to interfere with that possibility.. without doing something like Deere has engineered.
Mine is over-ridden, as I don't mow with children anywhere near my running mower when mowing.
But there are careless operators, non-the-less.
I made a U-turn in the road a few years back to inform a mower operator that his child being pulled in a little wagon behind his mower while he mowed the lawn was foolish and the child was at high risk of being injured from thrown stones or debris and could get an eye put out. He wasn't impressed, but hopefully gave it some serious thought after I left.
   / How is this a safety device?? #4
As Jesse Ventura once said, "You can't educated the ignorant"
   / How is this a safety device?? #5
If he said that he's ignorant because you can educate the ignorant, but you can't fix stupid:D
   / How is this a safety device?? #6
It allows the manufacturers to say that you, the owner did an action that increased the liability of backing over your child and chopping them into little pieces, therefore we are not responsible for your negligence to properly protect your child.
   / How is this a safety device?? #7
Good for you! Also if he had other children, they could run up wanting a ride. Same goes for riding a child on your lap or one knee, not a safe practice.
   / How is this a safety device?? #8
I always thought the RIO button on the JD's was really really stupid, because it focuses your attention on the button looking forward when you want to go in reverse. I think they want you to override it so if you do run over someone while mowing in reverse they will be protected in court.
   / How is this a safety device?? #9
My Father-in-law has a Craftsman riding mower that two alternate positions. If you put the key in one of those after starting it will allow you to mow in reverse without holding any buttons - also, the other alternate position not only allows mowing in reverse, it allows you to get off with the motor still running. His came that way, he did not change anything.
   / How is this a safety device?? #10
That is how Cub Cadet's system works, but you have to press the "mow in reverse" button once each time you start the tractor.
Aaron Z
JOHN DEERE 329DT SKID STEER (A51242)
JOHN DEERE 329DT...
CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
CATERPILLAR D6T...
7021 (A50322)
7021 (A50322)
John Deere 7130 Loader Tractor (A50514)
John Deere 7130...
2007 Peterbilt 378 Semi (A50514)
2007 Peterbilt 378...
Deere 9965 Cotton Picker (A52128)
Deere 9965 Cotton...
