chopped
Hi there. I have a question for anyone with knowledge about water pressure drops.
The situation is a main house with a well and pump system. It then feeds water to a trailer that is 1500 feet away. using either 3/4 or 1 inch black poly pipe.
The problem is low pressure at the trailer end. expecially when the main house pump is at cut in pressure.
I was considering adding this pump and tank inline at the trailer.
Flotec 1/2 HP Shallow-Well Jet Pump Combo-FP41 515H - The Home Depot
No need to prime as the water would be in the inlet and then the outlet feeds the trailer.
Also I just thought if a tank ALONE would help this . like this one
Water Worker 2 Gal. Pressurized Well Tank-HT2 B - The Home Depot
I couldnt find a simple online pressure drop chart to tell just how much is lost in the 1,500 foot run So was wondering if there is a formuler for this also.?
Thanks
Thanks
