Buying Advice Ford 4610 SU or 4610 LCG
   / Ford 4610 SU or 4610 LCG #1
jdsilvers
Montague, NJ
Ford 4610SU; Sold my Kubota BX-22
I am looking at purchasing this tractor, but don't know which 4610 it is. Can someone help identify it? It says SU on the side, but looks like LCG tires.
Thank you.
   / Ford 4610 SU or 4610 LCG #2
I'd have to dig out some old sales lit, but I thought LCG was an option on the SU? The tractor in the pic is definitely lower than a normal 4610.
   / Ford 4610 SU or 4610 LCG #3
It's definitely lower than my 3910. Tractor Data says the SU (Special Utility) used the smaller chassis from the 3000 series with the engine from the 4000 series. The smaller rear tires also set it closer to the ground.
   / Ford 4610 SU or 4610 LCG #4
I recall the SU was a normal looking tractor from a tire size standpoint and I almost bought one when they were new. I may still have the sales brochure and recall nothing like the model shown with the smaller turf tires/wheels. It was a desirable model and my guess is that someone just stuck those tires on to make it a lawnmower for maybe a school or whatever. SU was for "Special Utility" as already stated and I thought that meant a little more of a basic, fewer frills tractor.
   / Ford 4610 SU or 4610 LCG #5
I believe it is a SU with low profile turf tires...
I own an 83 4610SU...
The SU has a shorter wheelbase, swept front axle, smaller fuel tank, and different tires than the all purpose...
The AP has the stronger front axle better suited for FEL use...
The drive train for both units are the same...
And yes, it is a very desirable tractor...
Thank you for the responses. I purchased it yesterday for $4750. It has 1900 hours on it. There is a small leak in the PTO seal, which I will fix soon. Everything else seems to work fine.
   / Ford 4610 SU or 4610 LCG #7
You did well...
If you are going to mow you may want to leave those low turfs on...
Personally, I would put the 16.9x24 factory tires on it but that is just my personal preference...
My SU has 2900 hours and I gave a similar price...
Mine had no leaks but a bad fuel sending unit that I repaired...
No issues in a little over a year of service other than flatting front tires from brush hogging...
I finally fixed that issue with Gensco air plane tires on the front...
I did add a ROPS and found a set of front weights with brackets from a gentleman that restores vintage Fords...
Also added a set of rear remotes and front head lights...
Need a paint job and the restoration is complete...
Give us a run down once you get it up and working...
Anyone know where I can get a good manual for the 4610SU?
   / Ford 4610 SU or 4610 LCG #9
Seems EBAY is a good bet, plus you can buy one on line. I might have an original sales brochure for one but I can't look for it right now. That's a great and trouble free tractor that you bought. Keep the center axle pivot greased and adjusted.
I have seen those with bigger tires and wheels on them--- 28" for sure and possibly 30" wheels.
EDIT--I just looked and you could order with 30" or even 38" rears to increase crop clearance.
2012 Ford E-250 Cargo Van (A56858)
2012 Ford E-250...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
New/Unused Quick Attach Auger with Three Bits (A57453)
New/Unused Quick...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2016 CAT 289D XPS High Flow Skid Steer (A59213)
2016 CAT 289D XPS...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A58376)
UNUSED HURRICANE...
