Oil Light on
   / Oil Light on #1
shovelrider
USA
YM1700 w / fel
I know i've seen somewhere about this, but can't find it. Anyways, was running ym1700 scraping some under brush. Temps around 88/93 index outside, and i am in shady area mostly. Oil stick is on full mark(clean oil), oil / filter change awhile back, haven't used tractor but 2-3 times since. And this morning it came on and hasn't turned off. Was pushing pretty good size loads of brush/dirt/logs etc.. It did however, try to stall a couple of times when running low rpms(1200). I mostly run around 16-1800 while pushing heavy loads or running bushhog. The oil sending unit is about 2yrs. old, maybe light indicator? What say ye' grand Yanmar wizards ??
   / Oil Light on #2
I wouldn't run it anymore without confirmation of correct oil pressure. Trying to stall is a good indication the light is telling the truth.
   / Oil Light on #3
It may be your current sending unit has gone bad, or maybe it has a piece of trash covering the hole inside blocking a good pressure reading. If you pull the sending unit and can't see anything, then I'd screw in a mechanical gauge and see what that says. The fact that the light is on is telling you that either you have low oil pressure or that the sending unit is bad.
Hopefully it's the sending unit, but a decent quality mechanical gauge will tell the story
   / Oil Light on
Had another unit, installed it lights off WooHoo ! Going to town tomorrow and get a mech. gauge, what is press. need to be approx.? Like to be able to read press., not wait on a light bulb to tell when it needs some attention paid to it. Thanx Jim
   / Oil Light on #5
According to the I&T manual 35 to 50psi.
   / Oil Light on #6
I would just call it a fix and move on unless you just want the extra work. Nine out of ten times it's the pressure unit. It transfers at about 4psi. A gauge requires a different pressure unit.
   / Oil Light on #7
Hoye's sight shows same pressure sender for 220 and 1700. Manual for 220 states light on below 14.2psi.
   / Oil Light on #8
I installed a mechanical oil pressure gauge along with voltmeter for giggles. It's always good to know what the engine is doing.
   / Oil Light on #9
No doubt I am probably in the minority but do favor oil lights for the simple reason one is likely to notice a red light come on. Unless you constantly monitor your gauge you could have 0 oil pressure before you even notice the gauge. Just a thought. It is important to assure they are in working order.
   / Oil Light on #10
Here's a longwinded thread I wrote when I had the same experience. Summary: Install the $6 sender that is common for 70's Honda, Subaru, Nissan and get on with life.
Low oil pressure? No, bad sender!
Here's a photo in that thread showing a water pressure gauge I mounted temporarily for diagnosis.
144606d1257399170-low-oil-pressure-no-bad-p1550937roilgauge-jpg
2024 DOWN TO EARTH 8' X 26' HYD TILT TRAILER (A52708)
2024 DOWN TO EARTH...
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
LILLISTON 4R ROLLING CULTIVATOR (A58374)
LILLISTON 4R...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (INOPERABLE) (A58214)
AM GENERAL M1123...
STIHL GAS POWERED HAND HELD BLOWER (A58374)
STIHL GAS POWERED...
2013 HINO 338 26FT BOX TRUCK (A59575)
2013 HINO 338 26FT...
