Burning Brush
   / Burning Brush #1
HillStreet
Maine
Kubota B2650HST. Kubota Z125S
We may get some rain in the next few days so I may burn some of my brush piles. The piles are dry, stacked since fall. My question is how should I light the piles? The actual brush is small with some larger limbs 4 inch or so. One pile is about 16 feet long, 6 feet wide, and 5 feet high. I have good clearance and will have a hose out there, and will have a permit.
   / Burning Brush #3
A roll of toilet tissue dipped in diesel works for me in getting a brush pile lit.
Steve
   / Burning Brush
That's a good idea, thanks Jeff. By the way, will it light if I try to do that in a light rain. Or should I tarp it before it rains?
   / Burning Brush
Good idea, I have the stuff.
   / Burning Brush #6
I start my piles by using what I start my fireplace fires with; little wood chips soaked in a diesel. Throw a handful in it and light with a small torch.
I would just start in one spot and watch it. It shouldn't get that big. You can always start on the other side also if you get bored. I always push the pile together with the tractor bucket as it starts burning down. The garden hose is a good safety feature in case you think it is getting to hot.
If you push burning coals to the center make sure you have a plan in case your tractor kills and can't get it started. :eek::eek::D It is a Kubota you know.
   / Burning Brush #7
Never approach a flaming burn pile in HST/High. It is too easy for pump momentum to push you in a little farther than you anticipate.
Use HST/LOW.
Not only the rain but the pile constituents and per cent of moisture in the pile determine it burn ability.
I would not tarp a pile. Just wait a few more days.
   / Burning Brush #8
I normally just save some old news papers and crinkle them all up and stuff them in the bottom of the pile, mix a little diesel and old oil together and sprinkle it over and light with a grill lighter.
   / Burning Brush #9
Wow! Is brush that hard to light? I guess I have been doing it wrong with a little piece of paper and stuff it down inside the pile and in about five minutes I have flames roaring out the top.
The OP lives in Maine which means the brush is probably a lot of pine - that stuff will light quickly and burn hot.
   / Burning Brush #10
If it's good and dry, I just burn my burnable garbage and that is usually enough.
I grew up throwiing (then cheap) fuel on a fire. We never had a loader to compact a pile and that makes a big difference. Now I use a hand held leaf blower for manipulation.
2019 Bobcat 3400 4x4 Utility Cart (A54811)
2019 Bobcat 3400...
2015 PETERBILT 389 (A53843)
2015 PETERBILT 389...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
CABINET (A53843)
CABINET (A53843)
Mobile toilet with shower (A53424)
Mobile toilet with...
Unused Delta Crash...
