Disc Harrow Appropriate disc size/type for 32HP tractor?
   / Appropriate disc size/type for 32HP tractor? #11
Depends on soil conditions but I would think a roto-tiller would work much better than a disc on that small of a tractor.Of course plow first.Big tractors with large heavy disc's are another animal all together.
   / Appropriate disc size/type for 32HP tractor? #12
Angle iron discs are a waste of money.
Maybe so- but they are great when they are free or virtually free...
For the Ops rocky soil a square tube framed disc would be better.
   / Appropriate disc size/type for 32HP tractor? #13
I guess it just depends on the use. I have never had the pleasure of working with a heavy box tube disc with large pans. But have used several lighter angle frame 16" and 18" pan discs over the years.
For primary tillage....yea they ain't designed for that. Working up plowed ground, or a plowed garden....they do as expected. Bust down the plow furrows and level things out. Don't know what more one can expect.
A few other uses we had found for the "worthless" angle iron frame discs over the years....
1. After reshaping an area or doing a lot of dirt work, it gets pretty hard packed. Use the disc as it breaks up the top few inches. Then throw down seed and culipack.
2. Rough and uneven areas of the yard. Disc it up, let the clods dry out a bit, culipack and roll. Most of the grass comes right back and is smoother than before.
3. After backfilling a trench from laying tile or whatever....it ends up real uneven when just shoving dirt back in with the FEL. One tractor running up and down straddling the furrow left from the backfill....breaking up clods and feathering everything out....another tractor with a blade angled to roll the dirt back overtop of where the trench was. This evens out the furrow left by backfilling, and when things settle, it's a much smoother finished result.
I would love to have a heavy tube type disc. But cannot justify the cost. And almost never see them come up used. Only saw one over the summer and it was 2-hours away. Had 24 20" pans...so about 7'. $1550 was the price.
My next disc is likely gonna be a transport type as they are lots cheaper. Seen some good looking ones for under a grand in the 10' range.
I potentially have the opportunity to try out (and buy if I can pull it) a JD 210 13' transport disc.just have to find the time to hook up with the farmer that has it, and see if the MX can handle that much disc
   / Appropriate disc size/type for 32HP tractor? #14
Yep. Bought my medium duty 12ft tandem wheel disc for $140 from a scrap yard. Pulled it home. Didn't even have to air up the tires. Didn't have a cylinder on it. Needed one bearing replaced. Perfect for what I needed.
   / Appropriate disc size/type for 32HP tractor? #15
Have you ever pulled it with that ford 3910? Bout the same HP, and ~500# heavier bare tractor and larger front tires. My MX would be heavier with the FEL on, (loaded rears also) but not ideal weight distribution with the loader on though. How many pans and what diameter? If your 3910 handles it.....it gives me some hope.
This is a JD 210 (not the actual one I am considering, but same model/size)
   / Appropriate disc size/type for 32HP tractor? #16
I Could pull a 16' transport disc in freshly plowed ground on the level or downhill with the 5083E, going uphill or in soft spots, I would have to bump the hydraulics to lift the disc a little. I never did get that disc set upright though. The front axle would nose dive and dirt would plow up over it between the pans. Give it a shot fellas and see what you can pull.
   / Appropriate disc size/type for 32HP tractor? #17
5083 w 16.9x30 rears and 11.2x24 fronts.....7200#....pulls 16' ok
MX5100 w/14.9x26 rears and 9.5x16 fronts.....4500# w/loaded tires and no loader.....up to 6200# with loader.........will it pull 13'......(we need a chin-scratch emoji)
Redneckracin: Did you pull that 16' disc with the FEL on or off? Those of you that have pulled bigger transport discs, do you find they pull better with or without the FEL? The FEL adds alot of weight, and normally weight is good.....but being a transport disc.....you are taking alot of weight off the bigger back tires?
I did pull the 3-14 plow, at a good 7-8" depth and had no issues. That was loader on. Didnt try it with loader off. Dont think I could have pulled any bigger though. I think a 3-16, cutting a tad deeper and 6" wider overall....would have gave me fits. I couldnt pull as fast as I wanted to either. Would have liked 5MPH. But M range on the HST tops out at 7.3, and just didnt have the nads. So was stuck with low at 3.7MPH.
I will say, plowing and watching that dirt/sod turn....that was quite enjoyable for the 1.5 acres that I did. Almost didnt want to stop....
   / Appropriate disc size/type for 32HP tractor? #18
LD, Well I had 4 suitcase weights on the front end (No loader), 2 cast wheel weights and beet juice in the tires so you gotta add about 2k lbs to that weight conservatively. Will the MX pull 13'? I'd just be guessing honestly, but you don't know until you try it!
:scratchchin: <-- you mean this one? :D
   / Appropriate disc size/type for 32HP tractor? #19
Yea, that's the emoji I was looking for. Must have overlooked it.
The plan is to try it before commitment, and he seller/farmer is fine with that.
Knowing how the MX, and even the l3400 handled a lighter 7' disc with 16" pans makes me hopeful. As well as overszd's experience....if that was with the 3910.
But then your experience needing 10k pounds and some bigger tires....has me wondering.
Will get around to trying it soon enough, that's for sure. That will tell me all I need to. I don't know anything about a 210, if it has 16 or 18" pans I think I'll be fine. But 20 or 22's...I think I'll have a nice anchor.
   / Appropriate disc size/type for 32HP tractor? #20
Well if you can try it before you buy it that's the best case scenario! Don't let me throw you to much, I was in freshly plowed ground, and I think I had the front gangs set to dig in way to much. I think I could have fixed that by adjusting the tongue but it wasn't my disc to be monkeying with. WE have pretty heavy soil in Western PA so I think that plays a pretty large role as well.
SINGER 211 UPHOLSTERY SEWING MACHINE (A54757)
SINGER 211...
2008 DOOSAN G25 GENERATOR (A53843)
2008 DOOSAN G25...
DEUTZ MARATHON...
UNUSED LANDHERO 1H-1W21 1" AIR IMPACT WRENCH (A57193)
UNUSED LANDHERO...
66'' root grapple (A53421)
66'' root grapple...
Deere 335P (A53317)
Deere 335P (A53317)
