Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,011
roadhunter: yes i will need to drive over the snow first.(never been a problem) over here it is normal to have a rear mounted snowblower to drag after you, and a big plow to have in fornt. this is only for private use :D
   / Pictures of your snow weapons #3,012
Interesting. I guess I can see how the plow would knock the snow down to a manageable height so the rear blower could be used. Probably Have 20+/- inches of clearance at the axles so as long as the front plow could knock it down I see how that would work as long as the snow wasn't' too deep. I can't imagine it would work very well trying to drive through a large drift though. Plus driving over it packs it down.
   / Pictures of your snow weapons #3,013
I think it was Fisher plows that used to say "Plow with the storm". That is the best approach with multiple feet snow storms. It also seems that "the big one's" are dry & fluffy, that rig of 2orodd's would not have much if any trouble with 3' of that type snow, esp with those chain's. So far I think he has the "baddest" tractor based snow weapon here:thumbsup:
   / Pictures of your snow weapons #3,014
Unless my eyes are deceiving me is that blower designed to be used going forward?
I can't say I've ever seen one like that where you have to drive over the snow first.
Inverted blowers are known as the most efficient style in the commercial snow removal biz.
Of course there are always exceptions to everything.
   / Pictures of your snow weapons #3,016
My primary is the quad. 1996 sportsman with 60" plow. Handles 90 percent of the snowfalls. If it gets too deep or if banks need to be pushed I use my 1964 Massey Ferguson 150 with snow bucket and 6 ft rear blade.
   / Pictures of your snow weapons #3,017
I have read as much as I could about how everyone has mounted plows on tractors. I took from that what I could and decided to do a frame mount Fisher MM1 plow on my Kubota L3200. I found a plow for $400.00. I have $400.00 dollars in steel and related materials. I have $150.00 in hydraulic hoses and quick connectors. So for just under $1000.00 and about 12 hours labor I came up with what you see in the pictures. The plow is 7.5 foot. Up/Down Left/Right run off the tractor joy stick. Unfortunately the up/down is on the curl / dump and the left/right is on the up/down due to the Regen feature of Kubota. Thanks to the members who helped me figure out the hydraulics. Now I just need to sand blast and paint, getting a little late may not happen till spring.
2016-10-25 14.51.44.jpg2016-10-25 14.51.36.jpg2016-11-01 15.35.09.jpg2016-11-01 15.35.30.jpg2016-11-01 15.35.00.jpg2016-11-01 15.35.37.jpg
   / Pictures of your snow weapons #3,020
CLUB CAR  CARRYALL 6 (A58214)
CLUB CAR CARRYALL...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
(2) 42" HANG ON FORKS (A54757)
(2) 42" HANG ON...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
2020 POLARIS RANGER 1000 RTV (A52708)
2020 POLARIS...
