Kubota RTV 500
   / Kubota RTV 500 #1
check 6
Gold Member
South Texas
BX 2680. Front bucket, grapple, pallet forks, box blade aireator 008-5 excavator ZD 1211 mower RTV 500
Anyone have any experience with the kubota RTV 500 utility vehicle. Specifically reliability, seating, quietness of the engine, and towing. how much tongue weight etc. Thanks, i'm looking as a better option than my current electric golf cart for work around the place
   / Kubota RTV 500 #2
I have 700 engine hours on my RTV500. Very reliable so long as non-ethanol gas (marine gas in Florida) is used. Same HST used in Kubota BX tractors, which is why Kubota utility vehicles cost more than belt drive competitors. Never have heard of any Kubota HST failing. Top speed is limited by HST, which is designed for low end torque, not top speed, to 25-mph. Fast enough for me.
I tow a robust MUTS all-terrain trailer behind my RTV500, usually carrying yard and tree debris, sometime 1,000 pounds dirt. The 15.8 horsepower engine/HST accelerates 1,000 pounds of dirt slowly, but satisfactorily ~~~~~stopping that 1,000 pounds of dirt in a straight line is more difficult. MUTS dumps 100% of loads, which few of its competitors do.
MUTS is the gold standard in all-terrain trailers and I highly recommend them. I abhor equipment down time.
((The Home Depot resin alternative is a POLAR. POLARs incompletely dump. Read POLAR reviews before making purchase decision. Some reports of wheel bearing failure. Photo #9 ))
RTV500 has never overheated despite 97 degree summer heat in Florida.
Engine is fairly loud, louder than the three cylinder diesel in my L3560 tractor. ((Less loud than the diesels in larger RTVs.))
I wear sound attenuating muffs when operating RTV and tractor.
If you work in woods, buy the optional factory roof. I have had large branches come down on the roof three times without damage to me or the roof. A person up to 150 pounds can work while standing on the roof, but I do not recommend that. :wink:
The REAR springs are adjustable in five increments, as operators vary from 80 pounds to 300 pounds. After a short time ALL RTV500's tilt to the left, at which time one adjusts/increases spring resistance on the left/driver's side to level up. Spring adjustment is covered in the Operator's Manual.
MORE RTV500: Google
MUTS: MUTS - Multi-Use Trailer System for your ATV, Quad and 4 Wheeler
   / Kubota RTV 500 #3
I have a 500, it has around 600 hours on it. It has run perfectly since day one, and it's had nothing put in it but E10 fuel...
It's used for work, pulling loads and hauling my tool box and other heavy tools in the bed, that's what I bought for and I'm happy with it.
My wife loves it as much as I do and she really wasn't on board, when I told her I was buying it! lol
SR
   / Kubota RTV 500 #4
I've got a 900 so can't offer much in regards to the 500. As to the RTVs in general. I consider them a work vehicle. Slow road speed. Rough ride. Poor suspension movement in rough terrain. A bit limited seating space, especially leg room.
I think of my 900 as a miniature 4 wheel drive ton truck with hydraulic dump bed. If you can pile it in/on the bed, it'll haul it. :)
   / Kubota RTV 500 #5
I have similar feelings about our RTV500, its a solid machine but ride comfort was not high on the list of design priorities.
Aaron Z
   / Kubota RTV 500 #6
My 500 rides better than my smaller tractors, and I spend hours at a time on them...
You guys must be softer than me?? lol lol
SR
   / Kubota RTV 500 #7
SR
Maybe you are just fatter and smash the seat better.... lol lol
   / Kubota RTV 500 #9
   / Kubota RTV 500 #10
RTV500 REAR springs are adjustable in five (5) increments, as operators vary from 80 pounds to 300 pounds. Spring adjustment is covered in the Operator's Manual.
The Operator's Manual calls for a special spanner to adjust springs, which Kubota USA does NOT stock. A set of good size Channel Lock pliers accomplishes the spring adjustment easily.
Have you gents commenting on a hard ride adjusted the springs? Kubota default position is the hardest setting. :duh::
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2016 Dodge Caravan SXT Van (A55853)
2016 Dodge Caravan...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2005 GMC C8500 Flatbed Service Truck (A55852)
2005 GMC C8500...
