Fencing Garden w/ Tractor Access
   / Fencing Garden w/ Tractor Access #11
Set up a food plot so they stay out of the garden ?
I'm a hunter, so there are plans for a food plot or 2, but not near the garden. We are planning a small orchard in the general area also, so there week be a more accessible for source for them, but I've seen as many as 12 doe/fawn at one time so I don't think leaving the garden unprotected would be a possibility. Time will tell though I suppose.
   / Fencing Garden w/ Tractor Access #13
The deer in my area laugh at a 6" fence. I had to add two strands of barb wire on top to finally keep them out.
   / Fencing Garden w/ Tractor Access #14
I doubt a 6 foot fence will keep deer out. But if 6' will do it, then regarding a gate, use a fence panel hung as high as the rest of the fence - put in a couple of wood posts with heavy duty eye hooks and hang it on those- easy to lift off for access. The span will have to be reduced a bit though - wide enough for a tractor and short enough to be able to hang a cut down panel. May also be able to add a rebar at the top of the panel to stiffen it a bit.
   / Fencing Garden w/ Tractor Access #15
I read about a gardener who kept out deer with a 4ft fence. He added sticks, at about 2ft intervals, that went up to about 7 feet. This fooled the deer who could have jumped between but didn't.
Like the red lines on this panel.
Bruce
   / Fencing Garden w/ Tractor Access #16
YEP! That's why all my fence has electric around the top. I have found that once the deer get zapped by that white tape they never go near it again. I can even put up the white tape without electric in some cases and get away with it.
   / Fencing Garden w/ Tractor Access #17
Solve your problem by getting a walk-behind tiller. People around here would laugh at you for trying to take a tractor into a small garden. The exercise will do you good too. :)
   / Fencing Garden w/ Tractor Access #18
Ditto here. My garden layout was based on a walk behind tiller in a 50 x 100 plot. When I moved up to a CUT tractor with implements, I had to remove one end of the fence each season in order to work it with the Kubota. That really is a PITA but works for me since that chore is easier than using the walk behind tiller. Gardening with a "tractor" introduces all kinds of complications however. 003.JPG004.JPG
P.S. I'll be 84 yo in a couple weeks..........is that an excuse to play with my Kubota in the dirt.:D
The first picture shows tilling with the walk behind.....the second one shows learning with the Kubota.:confused2:
   / Fencing Garden w/ Tractor Access #19
I used one of the gates fromTSC for my wife's garden and made a wooden walkway gate.
I did the same thing using a 16 foot tubular gate and attached net wire fencing to it. I first put in a 4 foot wide wooden gate for access but now that I put in the 16 foot gate, I don't use the man gate.
It all depends on how much you want to spend to have a gate.
We've discussed it, however, I think in the long run having the tiller will be more useful. Outside of the yearly garden work (which could expand once my kids enter school), there are a few food plots I want to do, and our front lawn needs to be torn up, leveled and restarted (about an acre).
1990 John Deere 2955 Cab Tractor (A55218)
1990 John Deere...
FAKE (A52472)
FAKE (A52472)
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
1996 Ingersoll-Rand VR642C (A47477)
1996...
2015 Ford Escape SUV (A53424)
2015 Ford Escape...
