thinking about buying a tractor
   / thinking about buying a tractor #1
05rammer
Missouri
I'm thinking about buying a tractor, what I'm looking for is one with a hydro transmission, mid pto for belly mower, cab and of course a loader. Was wanting your advice on which one. Also how is cut quality of a belly mower. I would be using it for yard work and snow removal on my half mile driveway.
   / thinking about buying a tractor #2
Any small compact or SCUT will do the job.
For a cab, you'll probably have to go small compact...no SCUT I know offer the option...unless you want to go with a soft sided cab like Curtis ? The cab is really a "NEED" or a "WANT"...they're quite expensive you know !
The hp depends on the size of the jobs you want to perform.
I would go with whatever brand the dealer is selling in your area....buying the tractor is easy, servicing it afterwards is what makes doing business with a dealer pleasant or not. A good dealer makes the whole experience much more pleasant.
Your question about MMM....they really do a very good quality cut, mine at least does...golf course quality...it's a 60" MF.
How do mid mount mowers compare to rear mount finish mowers
Rather not have a soft cab
   / thinking about buying a tractor #6
B2650 HSTC Kubota would be my choice.Looked at the small Mahindra cab and it didn't have air conditioning.
   / thinking about buying a tractor #7
Most folks buy somewhat based on the dealers near them. This doc helps by showing some of the more common brands.
https://www.ne-equip.org/wp-content/uploads/2016/05/2016_Survey_Report_Final.pd_.pdf
All the top brands have good machines so don't fear getting a bad one! Typically you will pay a bit more for JD and Kubota compared to others. A lot of machines are made by someone else. E.g. Yanmar contributed to JD. Mitsubishi to Mahindra and LS to New Holland and so on. I recently was looking at 25-39HP machines. I liked some of the Mahindra stuff, Kioti, some of Kubota. Yanmar has been ramping up in their own machines in the USA but they hadn't shipped to dealers yet- they looked nice though. LS didn't have anything around me but they are rated well. JD was tough for me. They use a proprietary loader attachment system that turned me off and they were quite proud of the product compared to others. I settled on what I thought to be the best dealer.
Can't speak to the mower part. Do you know what HP range you are looking at?
   / thinking about buying a tractor #8
If you are mowing large areas with few obstacles a rear finish mower would work well. If you are mowing in an area with lots of obstacles the mid will be better due to shorter turning radius. Both types do a fine job. I've used a rear finish mower the last 20 plus years.
   / thinking about buying a tractor #9
A MMM and a RFM both work well. I much prefer a separate mower to either option. A zero turn mower is the usual mower of choice unless the terrain prohibits that. A RFM is less of hassle than a MMM and has a better resale value. RFM = rear finish mower. MMM = mid mount mower or belly mower. FEL = front end loader.
   / thinking about buying a tractor #10
Quality of cut is pretty much the same.
But as said above, much better maneuverability with a MMM...but for large lawns without obstacle, a rear mower can do the job as good.
I own and operate both so I talk from my own experience.
What size (hp) are you looking for.
1995 Freightliner FLD120 T/A Wet Kit Day Cab Truck Tractor (A55973)
1995 Freightliner...
2012 DIAMOND C 40FT GOOSENECK TRAILER (A58214)
2012 DIAMOND C...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
Husqarvana Riding Mower (A56857)
Husqarvana Riding...
