So the engine is from Ford? Call the Ford parts dept and ask them about using 15w40. I thought they went with a Jasper since you were talking about a high volume oil and all the redesigned parts and since they wanted to change the oil in 500 miles.
The Ford GT does take 5w50 but not high Zinc.Well they are IDIOTS!!!!!! Let me make sure I was clear, T H E Y A R E I D I O T S!
Apparently NOT. I can assure you no rebuilder "redesigned" the engine, they have neither the mental nor financial capacity to do so. It is WELL understood in the Ford community that even 10W-40 oil can do SEVERE start-up damage to the "modular" engines. This is because of the time it takes oil to reach the cam bearings on an OHC engine. Additionally, the 3V engines have VCT (variable cam timing) which are "powered" by engine oil. Ford specified 5W-20 oil in these engines for a number of reasons, if the engines in the Ford GT don't need "special oil" at 500HP/500Tq, then it stands to reason these rebuilders are off their rocker.
The rebuilder did not redesign the engine. These are Ford improvements. Not sure where the oil requirements are originating. but Ford engineers tweaked this engine calling for different pump, tighter machine tolerances, etc.
Definitely not Jasper, the shop said they avoid them like the plague. It's not direct from Ford. Saved $500 by going this route but it is all Ford parts.So the engine is from Ford? Call the Ford parts dept and ask them about using 15w40. I thought they went with a Jasper since you were talking about a high volume oil and all the redesigned parts and since they wanted to change the oil in 500 miles.
From what I understand, Ford did make modifications to the cam phasers, timing chain and oil pump in later years. I hear you on the tighter tolerances comment. I was scratching my head on that but I think it was more about the settings on the variable timing being tighter, not machining tolerances. Not sure though.Ford ABSOLUTELY DID NOT "redesign" the engine and has NEVER EVER recommended 15w-40 oil in them.
Higher numbered oil is the OPPOSITE of what you need for "tighter machine tolerances" - yet another clue the rebuilder is clueless.
