Stupid easy LED lighting in the barn or shed
   / Stupid easy LED lighting in the barn or shed #1
49tandc
Member
N. Central Fla
SAME Argon 50/FEL; IH B414
I've had old T-12 florescent lighting in my shed for 20 years now. Three rows of four 2-bulb metal fixtures. Center of building is 16 ft tall. Had typical florescent issues - flickering, dim sometimes, especially when below 50 degrees, humming ballast, hard to replace the center row bulbs... I recently bit the bullet and bought some "Bypass Ballast" LED bulbs that use the old fixtures and tombstones, but require no ballast at all. While I was rewiring the fixtures (VERY EASY), I thought - Huh! I could mount some tombstones in an eight foot piece of PVC rain gutter and mount this over my toolboxes. I could also use these 'rain-gutter' fixtures down the center isle of our barn. These bulbs are 2400 Lumens each and are suited for damp conditions - just cannot use a dimmer with them, but didn't intended to.
I went to HD and bought a 10 ft section of PVC gutter. The metal gutter is more rigid, powder coated white outside, but grey inside where PVC was white inside and out, so better reflection. I cut it down to 100 inches and mounted the tombstones. (8-32 X 3/4 in little bolts and a drop of Gorilla glue on each tombstone because I'm **** about things being mounted well). Only one end of the bulbs get the wiring, the other tombstone just holds the bulb in place. I wired up the tombstones in the middle and drilled a whole in the PVC for the wires to feed thru and connect to my power (facing away from each other to give me an 8' strip of light) . I screwed an 8' piece of 1 X 4 pine to the top for some structural integrity, screwed in some eye bolts into the wood - one at each end and one in the middle for hanging the thing. Connected to power, turned on the switch and received immediate gratification!
These things work like a champ!! Instant on, no flickering, no heat, no real weight and great light.
Bulbs are $10-15 each depending on where you get them. Tombstones are @1.99 a pair at Ace Hardware. I first bought 4 bulbs at Ace @ $15 each, but they included new tombstones. Gutter itself is under $4 if you do not want too use the ends. The gutter-ends add another $7, but look nice and "finished". On the high side this makes about $42 for an 8 ft fixture. Then I got a box of 25 bulbs online for $10 each with free shipping.
If you want to experiment, try making a just a 4 ft one with just one bulb. You will be pleased. Once you make one, you will instantly think of other places that need additional light or other nifty things to hand the tombstones on. Like a rain gutter one (will accept damp conditions), outside over the Garage door opening ad wire it to the garage door opener... and this type of setup may be the answer. Its also the last light you will have to buy.
49T&C
   / Stupid easy LED lighting in the barn or shed #2
I like it, 49t&c. Very resourceful.
I expect the Flat Earth Society will be along shortly to poo-poo the idea.
   / Stupid easy LED lighting in the barn or shed #3
You can't make those things!.... oh, wait, he just did! :)
   / Stupid easy LED lighting in the barn or shed #4
I installed LED strip lights under my kitchen cabinets last year and they would be super to light up a barn or garage. They just mount with a self adhesive backing. Only problem is the cost right now is $250 for a 12 ft strip with 600 LEDs and that have 7 light levels and 7 shades of white using the included remote.
   / Stupid easy LED lighting in the barn or shed #5
When those prices come down a bit, I would like to switch over. Right now it's too expensive.
   / Stupid easy LED lighting in the barn or shed #6
Here's another low dough solution. I have all 8 foot fixtures in my shop. The ballasts are dying the death of a rag doll and so are the lamps...both are $$$ to replace. I bought a roll of self-adhesive LED tape and a power converter box from Amazon for around $10. Rip out the old 50 lb ballast, toss the lamps, install the new power supply inside the fixture. Run the tape down one side and up the other and plug it in. Instant LED light fixture. One shade of brightness and no remote control.
   / Stupid easy LED lighting in the barn or shed #7
I also made my own "fixtures" from 1 x 4 wood strips. I bought Chinese 5' power cords, light chain and tombstones from fleabay and I'm into the fixtures for very little money and they work great. LED bulbs don't care how the electrons get to them.
SimS
   / Stupid easy LED lighting in the barn or shed #8
Some of you guys are pretty innovative :thumbsup:
   / Stupid easy LED lighting in the barn or shed #9
For new installs, it's getting hard to compete with off-the-shelf LED units. I paid about $40 for some 4' units with 4000 lumens and a nice heavy duty diffuser lens. Seen others as low as $20. But for retrofits, the ideas here are great. I have fluorescents in my shop that are doing fine, but if/as they die, I'll convert them to LED. Being able to leave the fixture in place will be a timesaver.
2018 International TMA (A55973)
2018 International...
2022 Chevrolet Tahoe SUV (A56859)
2022 Chevrolet...
2020 Case 5550 Trident (A56435)
2020 Case 5550...
2008 Ford F-150 Ext. Cab Pickup Truck (A56858)
2008 Ford F-150...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
