Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #3,661
Tactical Nuclear Snow Weapons
European Farmers sure do have the finest stuff.
Just big fast fancy utility tractors for instance.
T Series
250 Max. HP
CVT or 30R/30F
42 gpm Hydrauloc flow
Bare tractor weight wit Fluids 16,000 lbs
Less than 18' turning radius, better than many small cars!
21,356Lb Capacity Rear Hitch,
11,465Lb Capacity Front Hitch.
With road gears the tractor could get a speeding ticket in every state but maybe Texas
Needs good tires,
Nokian TRI 2 Extreme Steel / Nokian Heavy Tyres
https://www.nokiantyres.com/static/.../assets/Nokian_Hakkapeliitta_TRI_Flyer_EN.pdf
Nokian TRI 2 / Nokian Heavy Tyres
New World Record for tractors / Nokian Tires
https://www.nokiantires.com/company...new-world-record-for-tractors-130-165-km-h-2/
   / Pictures of your snow weapons #3,662
Every watch on youtube when they plow roads w/those beast...no mercy. :eek:
   / Pictures of your snow weapons #3,663
Fastrac - Snow Plough - Norwegian - YouTube
In Europe where we use truck for snow plowing, Grading implements for rural road grading and maintenance, hauling dump trailers with aggregate, and short haul of Farm products and supplies, large Ag tractors do double duty and are common on the roads.
That's why a high horsepower utility tractor across the pond is considered barely adequate, and the high power European utility tractors are about 1/3 higher hp tractors than best you see in the States.
The higher speed tractors have front suspension. A tractor opening the first race of World Rally Championship in Finland - YouTube
Factory Stock except for engine control software tweeks, good tires, and road gears, and it could plow a field.
Valtra S 274 vs Fastrac 831 - YouTube
   / Pictures of your snow weapons #3,664
Mike
I'm confused.. is location Central NH meaning New Hampshire? You talk like you are in Europe?
   / Pictures of your snow weapons #3,666
Mike
We in USA use trucks for plowing snow mostly, except upstate NY etc, maybe. USA uses construction equipment for almost all infrastructure. Europeans are more versatile. Take a Uni-mog for instance.
+20% of cars are diesel. Just find it interesting.
PS for every town name in New England, you can find same in England. Early settlers must not have had much imagination.
   / Pictures of your snow weapons #3,667
The video of the Norwegian tractor plowing was considerably on fast forward.. if tractors work good for them, that is great.
The plow driver was cute, to say the least. :D
   / Pictures of your snow weapons #3,668
My 1968 Ariens 10M5 mule with a 7-10M snowblower attachment. Re-powered it several years back with a 7hp snowking.
   / Pictures of your snow weapons #3,670
I have my dads, in the lean too. If anyone wants to give it a good home, PM me.
Cast iron Gearbox, metal is at least twice as thick as the box store new ones.
Made in USA , I suspect. I've spent many hours behind it way back.
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2014 Ram 1500 4x4...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55314)
2011 New Holland...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
PALLET OF SPRINGS AND U BARS (A55745)
PALLET OF SPRINGS...
