How to choose a portable battery jump starter?
   / How to choose a portable battery jump starter? #11
Try one of the capacitor start jumpers. No batteries to go bad, weigh only a couple of pounds & small enough to keep in a glove box of a car. I bought one last year for a Kubota engined Cushman Truckster because I was sick of carting around jump leads & a heavy battery (the only spares I had were pickup sized).
Kubota has done over 9000 hours & needs 15 secs of glowplugs to start. Battery is an odd size in a small battery box, so this capacitor starter seemed worth a try at £90.
It works perfectly & will charge itself up & start an engine if the battery shows more than 5V! Can be precharged from a good battery too in which case it will start an engine without a battery.
I even used it to start my tractor the other day ( 2.4l 45hp UTB 445DT) - the first time in 11 years it wouldn't start - stll on the same battery too!
ElectroStart(R) Batteryless Power Start 16A 12V E/START16: Amazon.co.uk: Car & Motorbike
   / How to choose a portable battery jump starter? #13
The one you suggest in much higher price than my budget. I believe one less than $80 would be better.
Go with the bigger one. It is multi-functional, and will give you the extra jump when needed. I have the 400 AMP model from AntiGravity, works great, will start a V8 without a battery. I would do the larger one just because... They are well worth the money.
   / How to choose a portable battery jump starter? #14
I have had good luck with this, and yes, I have used it tro start my tractor.
OK. Thanks a lot for your suggestion.
Kubota has done over 9000 hours & needs 15 secs of glowplugs to start. Battery is an odd size in a small battery box, so this capacitor starter seemed worth a try at 」90.
ElectroStart(R) Batteryless Power Start 16��A 12V E/START16��: Amazon.co.uk: Car & Motorbike
   / How to choose a portable battery jump starter? #16
If you decide to go with lit-ion batteries, read this review from Consumer Report about storing them in your car. They say all of the 10 models tested failed when temperatures reached 0 degrees fahrenheit. And they don't like being over 120 degrees, as in a parked car in the sun.
I'm following this thread because I would like to buy one someday and don't know which ones are worth my money.
Best Jump Starter Buying Guide - Consumer Reports
   / How to choose a portable battery jump starter? #17
I was just going to suggest Consumer Reports - as was just mentioned above. Also, usually always several reviews and comparison charts that you can find on Google ranking the best ones.
__________________________
Victor | Roadside Assistance
OK. It is really helpful. Thanks a lot.
   / How to choose a portable battery jump starter? #19
car starter also needs to be recharged just like a regular battery to make sure they are ready to go in an emergency. That means that you may have to carry a heavy jump starter from your car to your house periodically to recharge it. i suggest only choice what ever company but select only that company which gives after sales services
I believe it is not a good choice.
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2018 KOMATSU PC88MR-10 EXCAVATOR (A60429)
2018 KOMATSU...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2014 Nissan Rgue SUV (A59231)
2014 Nissan Rgue...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
