f 2690
   / f 2690 #31
Seems like a good way to cut off a toe or 2. JMHO
   / f 2690
The 1 to 1.25 inch level is where I have cut for years. The places I cut mostly have a sprinkler system...maybe that is why they tolerate the lower height? I still need to disable the seat cutoff switch!
   / f 2690 #34
Under the seat is a connector. Unplug it. Build a short wire with the correct crimp connectors on it. Plug it into the wire coming from the mower, looping it back to itself to close the seat circuit.
   / f 2690 #35
When I get off the tractor to pick up trash, etc. I have to disengage the pto and put on the emergency brake. When mowing the soccer fields at church that was about 20 times.
Way too much trouble. I did it on my old MC35 New Holland (also a front mount mower like this one) and it makes a huge difference.
way
I'd be telling the church to let the people know not to be littering, it's both impolite and rude to the church.
   / f 2690
They do clean up for the most part....but with 200 kids 4 days a week, things tend to slip through the cracks. I found the connector and will very soon have the bypass surgery performed!
   / f 2690 #37
I just picked up a new 2690 based on the recommendations on this forum. I got my first hour of seat time last afternoon and I am impressed. I sold my ZD331 and was worried about losing 5hp but I could not tell any difference at all and my grass was unusually tall because of a delay getting the new mower. There was plenty of power.
I got the 72" rear discharge and it made a huge difference in mowing comfort. I have pretty bad allergies and it is always windy here on top of a big wide open hill. I would not say that I felt refreshed after mowing (still some dry weeds blowing around and getting in the eyes- there was 20mph wind yesterday) but I was certainly not covered in grass/weeds and miserable like I was with the side discharge. I thought the ride was surprisingly rough until I let a bunch of the air out of the tires and then it rode very nice! Much nicer ride than my ZD331.
Overall I'm impressed and glad I made the change.
   / f 2690 #38
As you'll see, with experience, the F is a class above the Zs. The rear discharge deck also does less windrowing if cutting grass at same level of growth than a side discharge. The F will cut taller grass better than the Z and faster in open areas with less steering wheel manipulation. Rear discharge F is the tops! Been saying so for ever 10 years beginning with a F2680e and also owning two different F3080s and slipping a ZD326 and a small Kubota Z in for a couple years trial use.
You'll not be disappointed. Read the old posts and replace those front wheel pins with hardened steel bolts/pins if your yard isn't a lawn. Keep the screen clean in dry mowing season/watch temp guage. Don't cut rocks/stones, it chips the blade edges.:D:cool2::drink:
   / f 2690
Here is my follow up report. Mowed about 10 hours this week on the mower. Beautiful cut. Rear discharge is perfect. Plenty of power. I can't tell the difference between it and my New Holland MC35 which is the same front mower layout. It has 35 hp, but I didn't miss it. I climbed some rather steep hills in the one spot I have that's hilly and did not have to shift into the slower gear. I bypassed the seat switch and that was a Godsend, for getting off to move 24 soccer goals and picking up water bottles, etc. it made a huge difference. My mower is set so low to the ground, I could get my foot up under it anyway. One strange happening was that when I finished, raised the deck to drive home (about 2 blocks), and upon arrival the deck would not go back down. Got out my manual and there is a little knob under the seat that controls this. I had not touched it, but at any rate, the manual said to slowly turn it counter clockwise....I did that and everything returned to normal. This is a top flight mower in every way! I also let some air out of the tires...dealer had about 40 pounds all around and the ride softened up dramatically.
   / f 2690 #40
I've also had the "deck lock up and not go down" happen to me a couple of times over the years. I called Barlows and talked to Gary and he told me to turn knob.:thumbsup:
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A54607)
2006 KENWORTH T800...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
